John Deere 670 Compact Tractor Alternator/Charging Issue
   / John Deere 670 Compact Tractor Alternator/Charging Issue #1
fratra
Somewhere, GA
John Deere 670
I have a JD 670 compact from 1996 I think. The battery light is on and not charging (confirmed with multi-meter), only getting 12 volts on battery while running. I've replaced the alternator twice thinking the first may have shipped bad. The second alternator the battery light went off initially and stayed off for several starts. As soon as I started backing it out the light came on and stayed on again. I did try changing the rectifier/voltage regulator and that didn't help either. Using a multi-meter I don't see any voltage coming out of the alternator connector wire either. I don't see any inline fuses I can find anyway. Any ideas??
   / John Deere 670 Compact Tractor Alternator/Charging Issue #2
You need the TM1470 service manual to debug this issue in the troubleshooting section.
(it's for free on the YTOG)
TM1470 Technical Shop Manual 670 770 790 870 970 1070.pdf
Awesome! Thanks for the help.
STORAGE FEES (A51219)
Toro Zero Turn Mower (A50324)
Toro Zero Turn...
2019 Bobcat T770 Two Speed Compact Track Loader Skid Steer (A50322)
2019 Bobcat T770...
2012 KENWORTH T800 SLEEPER (A50854)
2012 KENWORTH T800...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A51039)
Kubota BX2680...
1999 John Deere 566 Round Baler  Net & Twine, Reliable Performance (A51039)
1999 John Deere...
