yankeerider
Platinum Member
My JD manual says the 755 uses a Yanmar 3TNA72UJ and the 855 a 3TN75 RJ engine. Maybe you can find dimension specs based on that?
Research the engine itself. Many of the 3TN series share the same block with same stroke... different bores size for different displacements. If you find a 3TN with the same stroke as your original engine, but with a bigger bore... it will more than likely be a straight bolt in. That was the case with my 955. The original engine was a 3TN84, but I have a 3TNE88 installed in place of the original. The 84 and the 88 have the same stroke.
