John deere 655 engine swap???
   / John deere 655 engine swap??? #1
coyote556
Hello,
I have a john deere 655 with a bad engine. there is no compression. if it would fit, I had considered switching the engine to a yanmar out of a 755 becuase of the additional horsepower, instead of repairing my engine or replacing it with the same yanmar. Does anyone know if this will work? My 655 has a yanmar 3TN66UJ engine. thanks for the help
   / John deere 655 engine swap??? #2
I can tell you how to find out.
Go to the John Deere website and go to the "lookup parts" section. By fooling around with the two model numbers and seeing what numbers fit where, you can determine the fit. I had a JD 900 and found out a lot of others would have fit. I'll bet your experience will be similar.
I had done that prior to posting on here, but the only engines it showed for a swap were the same model yanmar, from different tractors. I was wondering if there were any yanmar experts who could tell me a similar model engine, with a little more power, I could swap out that would still fit? thanks
   / John deere 655 engine swap??? #4
I compared the crankshafts, clutches and transmission parts among others. It gave me a general guideline that suggested it would fit. I sold the tractor so I never got to finish but would have tried to find the swap tractor and measure from that.Maybe you could find one in a junkyard?
i didnt think of checking crankshafts. that is a good idea. I just checked shortblocks. thanks
   / John deere 655 engine swap??? #6
There is also a "where used" function of JD parts that tells you where a certain part will fit and in which tractor models used. That was very helpful. I'll bet your engine is one with a hard-to-check oil dipstick that ran low on oil and burned the bearings. Mine was. If so, check the oil pressure with a gauge on the new one.
I looked and the 655 and 755 were made over the same time frame and both had hydros available. I would check overall length of both tractors and compare as well as what type of hydro available. Also compare hoods to see if interchangable. Yanmar/JD made that whole class of tractors somewhat similar and share design similarities. I'll bet it fits.
I can't find it right now but I actually have a sales booklet on either that line or the 650/750 group from the 1980's.
After I weighed all my options I decided to sell the old and replace with a different tractor.
Well, it does not look good. The valve cover is different, as is the crankshaft and hood. I noticed the 755 holds more fuel, so i thought the tank maybe bigger, resulting in a longer hood, but who knows. The valve cover and crank being different really discouraged me.
   / John deere 655 engine swap??? #8
Not done yet. Call a tractor junkyard such as one of the big ones in Ohio. Search the net for names and ask if they have any info on your question.. Some will list what they have for models. most have a book of cross-reference that might help.
You could also stop in a JD delership Dervice dept and try to find an older guy that might have an idea. Ditto to call one of the big Yanmar dealers--there is one is sourthern Tenn--maybe Wincester or close by.
Remember to check overall length of tractors and see if close. Back out tire diff and see what you have
   / John deere 655 engine swap??? #9
Coyote - I've got a 655 myself. It starts like a bear. How did you finally realize it had bad compression? I should find out once the weather finally breaks. New to all some this myself. Thanks for the info.
I actually bought it that way. I planned on trying to get it going. They guy I bought it from took it to the local deere dealer and they told him it had little to no compression. I plan on testing the compression for myself to be sure. I know one thing, it definately will not start.
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
BUSH HOG 32601 - 6' ROTARY MOWER (A51243)
BUSH HOG 32601 -...
2019 CATERPILLAR D6 LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2012 Toro Greensmaster 1600 Walk Behind Mower (A48082)
2012 Toro...
2005 Chevrolet C4500 Altec Bucket Truck (A50323)
2005 Chevrolet...
2002 International 4400 SBA 4x2 Flatbed Truck (A49461)
2002 International...
