John Deere 650 Tractor
/ John Deere 650 Tractor #1
edkemper
Klamath Falls, Oregon
JD 210LE, Case 580CK Series B Backhoe, 1991 WoodMizer LT40 Log Mill, 1989 JD450E Crawler Tractor, FordsonMajorDiesel
Can anyone tell me about a John Deere 650 Tractor? I am looking for a relitively inexpensive tractor to use primarily digging post holes.
I found a 1983 John Deere 650 Tractor on craigslist for $3500. 2 cylinder diesel, front and rear PTO, 3-point with just over 700 hours.
Would adding this to my equipment inventory be worthwhile?
Thanks in advance.
/ John Deere 650 Tractor #2
I had a 755 same series, and it was a wonderful tractor, I loved it. Most anything will work for a post hole digger. If its in good shape should do fine.
/ John Deere 650 Tractor #3
It vibrates and runs rough like a typical 2 cylinder, but will burn less fuel than a similiar 3 cylinder. Small, maybe 12hp. My neighbor had one with a loader and backhoe, he cleaned out horse stalls with it. We had a 750 when I was young, I learned to drive on it. Never had any trouble with it, other than needing a bigger tractor for the buisness, and traded it in. The 50 series by John Deere were well built machines in general.
/ John Deere 650 Tractor #4
Does it have a full travel Cat1 or Cat1-limited 3 point setup? Cat1-limited can not raise as high or spread as wide.
/ John Deere 650 Tractor #6
Those older Deere CUTs had a standard CAT 1 3PH. The only limitation to lift height was due to the smaller diameter tires.
I had a 670...good machine and sometimes I wish I still had it. They were tough and, for their size, quite overbuilt. In fact, you'll likely see some of the castings used on the 3005 Deere CUTS today.
2014 REITNOUER MAXIMISER 48' FLATBED TRAILER (A59905)
2014 REITNOUER...
Land Pride FDR1660 (A53317)
Land Pride FDR1660...
2023 Kubota M7-174P (Premium) 4WD Tractor - 400 Hours (A61307)
2023 Kubota...
2015 BMW 328i Sedan (A59231)
2015 BMW 328i...
2019 Deere 550K (A53317)
2019 Deere 550K...
Massey Ferguson 92” PTO-driven rear-mount snowblower
Massey Ferguson...
