John Deere 650 Tractor
/ John Deere 650 Tractor #1
edkemper
Gold Member
Klamath Falls, Oregon
JD 210LE, Case 580CK Series B Backhoe, 1991 WoodMizer LT40 Log Mill, 1989 JD450E Crawler Tractor, FordsonMajorDiesel
Can anyone tell me about a John Deere 650 Tractor? I am looking for a relitively inexpensive tractor to use primarily digging post holes.
I found a 1983 John Deere 650 Tractor on craigslist for $3500. 2 cylinder diesel, front and rear PTO, 3-point with just over 700 hours.
Would adding this to my equipment inventory be worthwhile?
Thanks in advance.
/ John Deere 650 Tractor #2
I had a 755 same series, and it was a wonderful tractor, I loved it. Most anything will work for a post hole digger. If its in good shape should do fine.
/ John Deere 650 Tractor #3
It vibrates and runs rough like a typical 2 cylinder, but will burn less fuel than a similiar 3 cylinder. Small, maybe 12hp. My neighbor had one with a loader and backhoe, he cleaned out horse stalls with it. We had a 750 when I was young, I learned to drive on it. Never had any trouble with it, other than needing a bigger tractor for the buisness, and traded it in. The 50 series by John Deere were well built machines in general.
/ John Deere 650 Tractor #4
Does it have a full travel Cat1 or Cat1-limited 3 point setup? Cat1-limited can not raise as high or spread as wide.
/ John Deere 650 Tractor #6
Those older Deere CUTs had a standard CAT 1 3PH. The only limitation to lift height was due to the smaller diameter tires.
I had a 670...good machine and sometimes I wish I still had it. They were tough and, for their size, quite overbuilt. In fact, you'll likely see some of the castings used on the 3005 Deere CUTS today.
SET OF (10) ACE CATTLE PANELS W/CONNECTION JOINTS (A60736)
SET OF (10) ACE...
2010 International 4300 Truck Altec DM47TR Insulated Material Handling Digger Derrick Truck (A60352)
2010 International...
TEST YOUR BID BUTTON! (A62129)
TEST YOUR BID...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2016 FREIGHTLINER CASCADIA (A60736)
2016 FREIGHTLINER...
Sdlanch SDLGM1220F (A60463)
Sdlanch SDLGM1220F...
