John Deere 650 Information
/ John Deere 650 Information #1
Drpower
Rochester NY
John Deere 170, 650
Does anyone have General or specific Information about the John deere 650.
/ John Deere 650 Information #3
I also have a 650 MFWD and if it was maintained and not abused will last a long time. Basically a no frills gear drive tractor that will do the job. 2 cyl Yanmar diesel with 8 forward and 2 reverse. Some parts are getting hard to find so hopefully your dealer will work for you. If you get it get all the books. About 150.00 but well worth it. Some stuff interchanges with the Yanmars so dont forget about those guys if you need them. 14.5 PTO HP. I run a 5 foot rear finish mower and the 59" front snowblower with no problems. Zahm & Matson here in Western NY has been good to deal with on parts. Good luck and hope this helps.
/ John Deere 650 Information #4
I have a JD 750, this info is from my 650/750 Tech (service) manual:
14.5 PTO HP at 2600 RPM
Bore and stroke: 3.15x3.35 inch
Displacement: 52 CI
Compression ratio: 22.5:1
Capacities:
Fuel: 6.2 gal
Cooling system: 3.7 qts
Crankcase (with filter change): 2.6 qts
transmission-hydraulic: 14 qts
Front wheel drive axle housing (w/MFWD) 3.2 qts
Clutch: single-disk, dry
PTO:
Transmission driven with overrunning clutch
PTO speed (engine RPM) 540 (2350)
Clutch: uses transmission clutch
Hydraulic system:
Type: Open center, constant flow
Working pressure: 2000 psi
Pump: gear pump driven by engine
Brakes:
mechanical dry, internal expanding shoe
Electrical:
Battery: 12 volt, BCI group 24, 370 CCA
Alternator: 15 amp
Dimensions:
Wheel base: 56 inches
Overall length: 102.5 inches
Overall width: 41 inches
Turning radius with brakes: 6.2 feet
Shipping weight: (equipped for average field service, without fuel and ballast)
wo/MFWD 1450 lbs
w/MFWD 1530 lbs
/ John Deere 650 Information #5
You can also go to tractordata.com and look for the JD 650. There are some spec's posted there on it. I would post the link here but not sure if it's ok to do that on this forum.
/ John Deere 650 Information #6
I own a JD 650 that came with my place. At one time it had a 72" front snowblower and mid mount mower but over the years and different owners alot of the attachment hardware for the implements is missing. So my neighbor and I now use it primarily for cutting pastures. What would you like to know?
2015 Ford Explorer AWD SUV (A66738)
2015 Ford Explorer...
Bell 500 Gallon Saddle Tank (A64119)
Bell 500 Gallon...
PALLET OF FUEL TANKS (A68842)
PALLET OF FUEL...
PRESSURE WASHER (INOPERABLE) (A68842)
PRESSURE WASHER...
TRAILER (A66736)
TRAILER (A66736)
2026 SG45 Hydraulic Stump Grinder Skid Steer Attachment (A66734)
2026 SG45...
