John Deere 6430 tractor
   / John Deere 6430 tractor #1
RogerHillier
yanmar 165d
Jan. 1 ,2026
JD tractor with 5000 hours on it will not start when it's up to operating temperature. It will only start when it's cold. Otherwise runs perfect.
This model doesn't have access to codes and will require an analyzer from JD to determine the codes. Does anyone have an idea as to what sensor may be at fault ?
   / John Deere 6430 tractor #2
During cold temp engine start does a cold start device such as air intake heater automatically engage? How long since fuel filter was changed? I suggest to check for good fuel flow from tank to inj pump. Is fuel tank venting?
Thank you for responding. The engine only starts when it's cold. It will not start when up to operating temp. Yes the fuel filter was changed and the tank is vented. I agree. I think it is a fuel issue or lack of fuel being supplied. There are a number of sensors controlling the fuel. The question is, which one acts up only when hot.
   / John Deere 6430 tractor #4
I don’t know what sensors are on your 6430 but a question that comes to my mind is what or which sensor would allow the tractor to run when warm but stop fuel flow when hot?
Have you checked the fuel shut off solenoid? If for reason it gets weak when warm and doesn’t pull in would definitely prevent starting.
I agree. That's the problem. I think there may be 3 involved. If I could only get the codes up , I think it would give me a good indication as to which one. I have a gut feeling I may have to bite the bullet and get a JD tech with an analyzer to solve the question.
Here in Northern Ontario Canada, a qualified tech are few and far between.
   / John Deere 6430 tractor #6
Are the three sensors in question accessible? If yes can you take a hair dryer or heat gun and carefully warm one up and then try to start the engine while cold? Might identify the problem and might just waste your time..🤷‍♂️
Thank You and an excellent idea. Two are fairly accessible, the third not so much, but it may work. It is certainly worth a try. It may be a process of elimination.
2021 CAT 289D3 (A60462)
2021 CAT 289D3...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2021 FREIGHTLINER...
2009 MULTIQUIP 25KW GENERATOR (A58214)
2009 MULTIQUIP...
2013 Ford C-Max Energi Hybrid PHEV Hatchback (A59231)
2013 Ford C-Max...
2014 Dodge Charger Sedan (A59231)
2014 Dodge Charger...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
