John Deere 6403 Thermostat
   / John Deere 6403 Thermostat #1
josh2500
Im trying to get the thermostat out of my 6403. The therostat housing at the end of the upper radiator hose is bolted to the block. Im assuming the thermostat is in their and it needs to be removed. However, there is a pressed in cooland line that is stuck in the housing. Any ideas how the housing is removed in order to get to the thermostat? Thanks in advance...
   / John Deere 6403 Thermostat #2
That pressed in line will slip right out of the waterpump so im assuming it'll slip out of therm housing too. I know the waterpump end of it has a rubber grommet that allows for removal and reinstallation.
It looked like the other end of it ran into the front cover. However, on the thermostat housing its pressed in with no rubber hose connecting it. It should just pull out?
   / John Deere 6403 Thermostat #4
Yes. Just loosen it up out of retaining clips, then go ahead and take nuts off thermostat housing. Work it back n forth, should slide rite out. A thin film of grease should help sticking it back in. Dont use soap because it'll cause sudsing and bubbles in the system.
   / John Deere 6403 Thermostat #5
PS the rubber insert is internal where you cannot see it with pulling tubing.
   / John Deere 6403 Thermostat #6
A tractor that new having stat problems ?
2018 FORD F-550XL SERVICE TRUCK (A51406)
2018 FORD F-550XL...
2012 Freightliner Cascadia - Class 8, 6x4, Detroit DD13 (A52748)
2012 Freightliner...
2017 Ram ProMaster City Cargo Van (A51692)
2017 Ram ProMaster...
2006 KENWORTH T800 TANDEM SLEEPER TRUCK (A52141)
2006 KENWORTH T800...
Cat 305.5E CR Excavator (A52384)
Cat 305.5E CR...
2013 FREIGHTLINER BUSINESS CLASS M2 VACUUM TRUCK (A51406)
2013 FREIGHTLINER...
