John Deere 640 hay rake.....
/ John Deere 640 hay rake..... #1
bdw593
Bronze Member
Webster County Kentucky
Mahindra 6025
I bought a the JD 640 hay rake cheap, and it appears to be in good condition. The only problem is the gearbox. The previous owner advised that it was working fine when he parked it. The pin that puts the rake into gear wont turn so i cannot get the rake into gear. Does this mean the gearbox is bad or what. How can I tell?...
/ John Deere 640 hay rake..... #2
Looks like the lever opens and releases a clutch pack which may be just a bit dry. Probably no big deal to take it apart and clean it up.
Thanks for the scematic, Ive looked everywhere on the internet for that. I opened the case up and cleaned out all the grease and found the problem. the part that releases the clutch had "jumped" the collar, i put it in place and got it working. While doing this I found the roller bearing to be bad, Part 22 I think). I gotta get this ordered from John Deere, and figure out how to fix it, any suggestions? Thanks Alot, BDW593
if anyone can post some pics of a restored 640 hay rake, or one in really good shape i would appreciate it. I plan on restoring this one, (paint etc. ) and would like some examples, also a up close picture of the gear box and the engagment leaver would be greatly appreciated. Thanks,
/ John Deere 640 hay rake..... #5
Hello. I have a John Deere 640 hay rake and want to know what lube or grease is used in the gear box? Mine works fine and is full of grease. Is this what they used grease not gear lube? Thanks
/ John Deere 640 hay rake..... #6
If seals were bad many times grease or corn head lube was used in lieu of 85-140 W gear oil & replacing seals.
Giyi BF47 Quick Attach Hay Spear (A60463)
Giyi BF47 Quick...
2012 MACK GRANITE-GU713 (INOPERABLE) (A60736)
2012 MACK...
2021 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A59230)
2021 Chevrolet...
OMEGA 20 TON CRANE (A58214)
OMEGA 20 TON CRANE...
CASE TV380 SKID STEER (A62129)
CASE TV380 SKID...
GEARMATIC WINCH CABLE DRUM (A58214)
GEARMATIC WINCH...
