John Deere 6220 problems with fuse blowing
   / John Deere 6220 problems with fuse blowing #1
Kyle Guy
limavegas
John Deere 6220
Controls to make the tractor move forwards and backwards, when I put it on, it makes a bleeping sound with a blue indicator light flashing. The tractor wont go backwards or forwards. The fuse has blown a few times (behind the seat) and i've replaced the fuse and the tractor functioned for a short period but this time the fuse hasn't blown but the tractor isnt functioning, any ideas?
   / John Deere 6220 problems with fuse blowing #2
More info please.
European model ? I am thinking limavegas is Ireland.
Cab or open station?
What fuse number?
I am guessing Power Reverser transmission? Is the Forward/Reverse control mechanical or electric?
Wild guess is Solenoid on transmission failed. Number 44 or 51 in the drawing.
More info please.
What fuse number?
Yeah european model, yep limavadys in northern ireland
it's a cab
On the column f04 down the rows in between the numbers 8 and 9 right beside it facing up and down is the fuse that blew a few times
The reverser transmission is electrical
Would there be any way of checking if the solenoid transmission 44/51 is working? and is it possible that they sometimes work and sometimes may fail?
I'll try to get more information if possible, thanks very much for replien
   / John Deere 6220 problems with fuse blowing #4
You should try and find out what "that" fuse controls, the problem lays in "that" circuit.
Could also be a neutral safety circuit gone wrong. Check for any broken "live" wires, one may have been shorting out to ground causing your fuse to blow until it finally burnt itself apart, so now, the fuse isn't blowing.
Found out the problem, it was a broken wire, as you lifted the steering console up and down, it gradually wore the wire till it broke, thanks very much for the help, it really appreciated.
7022 (A50322)
7022 (A50322)
Guard Rail Pieces (A51692)
Guard Rail Pieces...
550 gal Gravity Flow Fuel Tank with Stand (A50515)
550 gal Gravity...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
John Deere 920 Platform (A50514)
John Deere 920...
