john deere 6105D thoughts
/ john deere 6105D thoughts #1
Robert_in_NY
Super Member
Silver Creek, NY
Case-IH Farmall 45A, Kubota M8540 Narrow, New Holland TN 65, Bobcat 331, Ford 1920, 1952 John Deere M, Allis Chalmers B, Bombardier Traxter XT, Massey Harris 81RC and a John Deere 3300 combine, Cub Cadet GT1554
I'm looking for a new tractor to take over for my old Ford 7710-II that is long gone. Primary usage would be pulling a 5-16 semi mount plow and a new Holland 575 baler. Would be a cab with FWA. I want a nice simple tractor that is reliable and easy to maintain. I've been looking at the Farmall 95 but would like to explore all my options. I have a friend who just bought a 6105D like I want setup but he has only put a few hours on it so far. Too soon for a good review. So any thoughts from you guys? Good or bad or any recommendations for different models that may be better suited for me. I'm looking to buy in time for next spring so there is no hurry at this point. Just preliminary research.
/ john deere 6105D thoughts #2
I think either the Deere or Case IH would be your best. Both have a good dealer network. I like the New Hollands also but I think I read somewheres you had issues with your dealer. My third choice would be Massey Ferguson. We have owned several over the years and have nothing but good things to say about them. I would pick them over a Kubota that size simply because they are made heavy before you have to add any weights.
/ john deere 6105D thoughts #3
On another tractor site a man stated he pulled a JD 7000 4 row planter with a Farmall 95 for 2.3 and it only used 2.1 gallons of fuel. That dang good fuel economy. for 100 hp tractor.
/ john deere 6105D thoughts #4
I think the D series tractors are fine. The 9x9 transmission is rather limiting, but if your looking for a plain jane tractor with no bells or whistles it should be fine. I have a 5083E and I was somewhat enticed by the 6D series until I started comparing features and they are a pretty bare bones tractor. If your spending alot of time in it a 5M might suit your needs pretty well to. I dont have any plowing experience with any of them though.
/ john deere 6105D thoughts #5
More gears is better! Especially baling hay. The newer M's are longer and weigh more than the 2012's, too. With filled tires, I'd think that 5 bottoms would be manageable with either the 5100M or the 5115M.
A lot depends upon your ground and soil type. Hilly and clay is a tough row-to-hoe... ;)
AKfish
I know the 9 speed tranny is limited and I'm fortunate to be able to try one out first to make sure. I think my tillage applications are a little much for the 5 series and a bigger and heavier 6 series should be a better tillage tractor and capable baling tractor.
/ john deere 6105D thoughts #7
if you want a used jd 4230 there is one on govdeals in ithaca new york
/ john deere 6105D thoughts #8
hey rob, let us know how it pans out, i keep bouncing back and forth between a 6D and a big 5M or even possibly keeping the "E" and finding a good 4840 for mowing and plowing. Possibly even big square baling.
/ john deere 6105D thoughts #9
All the numbers seem to point to the 5E.
I have noticed a lot of Kubota tractors mowing the ditches lately. I am wondering if JD has priced themselves out of the market.
D.
/ john deere 6105D thoughts #10
All new equipment is high $$$ but I know one thing on my '11 65 pto hp Kubota. I can operate the FEL,3 pt and hyd reverser without the aid of an electrical relay.
/ john deere 6105D thoughts #11
I dont mind the electrical relays.
The Ehitch on my 5525 is wonderful when you are hooking up 3 point items alone.
D.
D.
To me I believe the 5 series is a little small for a 5-16" plow. Outside of that it would handle all of our current equipment.
/ john deere 6105D thoughts #13
Dont forget, the E has a toplink sensing 3pt. I think you have to go to a 5M or a 6D for bottom link sensing.
/ john deere 6105D thoughts #14
D.
Electrical relays are wonderful until they quit operating correctly and need to be diagnosed and replaced.. This is especially true if it's in the Winter and you're about to get stuck when the relay fails. Just check out the number of threads on problems caused by relay failures.
/ john deere 6105D thoughts #15
i am with tx jim ,i do not like electrical relays .they always seem to quit when your in a strain.i think a 6105d would be a good tractor.
/ john deere 6105D thoughts #16
Ok you guys have peaked my interest. I am going to go check out a new 6105d. The changes for 2013 look nice.
I do wish it had more gears.
D.
/ john deere 6105D thoughts #17
What did you find feature wise on the 5e that was better than the 6d?
D.
/ john deere 6105D thoughts #18
The 6D is is cheaper than the 5M.
The ehitch and transmission options would be nice but I am thinking I will have a 6D soon.
D.
D.
I'll be looking forward to your review if you get it.
/ john deere 6105D thoughts #20
Sure thing.
I am still debating h260 vs h310.
D.
Kivel 48in Forks and Frame Skid Steer Attachment (A64553)
Kivel 48in Forks...
Gehl RS6-34 (A64119)
2011 Takeuchi TL250 Compact Track Loader Skid Steer (A64553)
2011 Takeuchi...
2012 Isuzu NPR HD w 5.2L 4HK1-TC Turbo Diesel (A63689)
2012 Isuzu NPR HD...
2015 CATERPILLAR 336FL EXCAVATOR (A65053)
2015 CATERPILLAR...
KUBOTA KX033-4 EXCAVATOR (A65053)
KUBOTA KX033-4...
