John Deere 60 troubleshooting
   / John Deere 60 troubleshooting #1
Marine2083
Marshalltown Iowa
John Deere 60
Recently bought a John Deere 60. ran fine last fall but now will not start. After charging the battery with leads inverted ( did not see it was a positive ground system)I have replaced the battery and installed it correctly but it will not start. Turns over very slow. Can anyone help me?
   / John Deere 60 troubleshooting #2
Welcome from Wisconsin,post the problem in John Deere forum.
   / John Deere 60 troubleshooting #3
Welcome from VA
   / John Deere 60 troubleshooting #4
Welcome to TractorByNet!
We moved your thread to the John Deere Vintage Tractors forum. :)
   / John Deere 60 troubleshooting #5
It's a basic question, but I have to ask. Are you sure you got a 12 volt battery? Some people are under the mistaken assumption that all 2 cyl JD's are 6 volt. If battery is correct and fully charged, then battery cables, and starter are the only things left in the cranking circuit. Are both of the cables in good shape? Do they have repair ends on the cables? If repair ends are used, be sure to disassemble the ends from the cable and clean that connection.
2013 FREIGHTLINER EXT CAB SERVICE TRUCK (A51406)
2013 FREIGHTLINER...
2013 Chevrolet Caprice (A50324)
2013 Chevrolet...
2004 Nissan Armada SUV (A50324)
2004 Nissan Armada...
John Deere 10 Shank Chisel Plow (A50515)
John Deere 10...
2024 AGT INDUSTRIAL QHT-500FL CONCRETE BUGGY (A51242)
2024 AGT...
2017 DITCH WITCH RT30 (A51243)
2017 DITCH WITCH...
