John Deere 5425
/ John Deere 5425 #1
JoeyMotes
5425 John deere
Power to starter relay but goes away when you engage starter switch.
/ John Deere 5425 #2
Welcome to TBN
What you describe sounds typical for loose/corroded battery cable connection or faulty battery. I suggest to clean/tighten all FOUR(4) battery cable ends & have battery load tested.
/ John Deere 5425
I just found the problem. In the wiring harness that plug in right in front of the cab. I unplugged it to start trying to Isolate the problem and seen where
Moisture had gotten in and corroded the power connection cleaned it and it started.
Thanks to your reply it got me started in the right directions
/ John Deere 5425 #4
Congratulations on your repair. Thanks for updating your results.
/ John Deere 5425
Thanks for your help and time.
/ John Deere 5425 #7
I’ve been having no power issues with my 5101E open station.
I replaced battery.
Then a month later : same thing no dash lights = Nothing.
Turned out to be a bad connection at positive battery terminal 🤬
And it wasn’t loose.
2016 Cadillac CTS Sedan (A64557)
2016 Cadillac CTS...
White 5409 9ft. Disc Mower (A65640)
White 5409 9ft...
(2) Caterpillar Skidsteer Tires (A66408)
(2) Caterpillar...
1024 (A63111)
1024 (A63111)
2018 JOHN DEERE 60G EXCAVATOR (A64277)
2018 JOHN DEERE...
JOHN DEERE 5075M TRACTOR (A63291)
JOHN DEERE 5075M...
