John Deere 5425 Starting Problems
/ John Deere 5425 Starting Problems #1
Dorie L
Just wandering if anyone has had problems getting their 5325, 5425 or 5525 Deere to start and stay running? Own a Deere 5425 and it will not run after setting for a few days. Have installed check valve in fuel system. The tractor will crank once and start, RPM's fall off/chokes down, and then will not turn back over. Please let me know if this has happened to you. Thanks
/ John Deere 5425 Starting Problems #2
I had a similar problem. I replaced the fuel filter and the problem went away.
D.
/ John Deere 5425 Starting Problems #3
I manage 10 of the 5325 tractors, knowing the electrical problems these tractors have I would tend to look there for your problem if it won't turn over after just starting. Maybe just a bad ground or moisture getting into a connection.Ours are open station and the moisture gets into the mfwd fuse panel and we loose transmisssion functions.
2008 SUBARU LEGACY 4 DOOR SEDAN (A64280)
2008 SUBARU LEGACY...
JRB 52" HANG-ON WHEEL LOADER FORKS (A63276)
JRB 52" HANG-ON...
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
84in. Light Duty Fork Extensions (A65640)
84in. Light Duty...
2005 MACK GRANITE CV713 T/A DUMP TRUCK (A64276)
2005 MACK GRANITE...
3pt Hitch Receiver (A62679)
3pt Hitch Receiver...
