John Deere 5425 Starting Problems
   / John Deere 5425 Starting Problems #1
Dorie L
Just wandering if anyone has had problems getting their 5325, 5425 or 5525 Deere to start and stay running? Own a Deere 5425 and it will not run after setting for a few days. Have installed check valve in fuel system. The tractor will crank once and start, RPM's fall off/chokes down, and then will not turn back over. Please let me know if this has happened to you. Thanks
   / John Deere 5425 Starting Problems #2
I had a similar problem. I replaced the fuel filter and the problem went away.
D.
   / John Deere 5425 Starting Problems #3
I manage 10 of the 5325 tractors, knowing the electrical problems these tractors have I would tend to look there for your problem if it won't turn over after just starting. Maybe just a bad ground or moisture getting into a connection.Ours are open station and the moisture gets into the mfwd fuse panel and we loose transmisssion functions.
2006 International SA525 Vac-Con V390LHA Combination Sewer Jetter Vacuum Truck (A46683)
2006 International...
14ft. Hay Rack (A49339)
14ft. Hay Rack...
2021 Chevrolet Tahoe SUV (A46684)
2021 Chevrolet...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A46683)
2009 Peterbilt 384...
Knaack Cart Armours Secure Storage Cart (A49251)
Knaack Cart...
Fisher Snow Plow (A49251)
Fisher Snow Plow...
