john deere 5420 fuel injection pump
   / john deere 5420 fuel injection pump #1
356mikey
john deere 5420
pump governor started acting up. did not maintain rpm well at all. last shut down took about a minute to stop running. i want to fix this one, but i had another pump.
other pump was installed due to misdiagnosed fuel problem. previous owner had installed inline fuel filter above transmission which clogged, out of sight. it was finally discovered when i replaced all fuel hoses and installed electric boost pump. this tractor did not have a tank outlet strainer. i put original pump back on because it was working well with new filters. now this pump is not starting. there is fuel pressure to pump, and flow from fuel return pipe at top of pump, but nothing at injector outlets. what am i missing?
   / john deere 5420 fuel injection pump #2
Try pulling out the check valve in the fuel line just above the hydraulic oil filter and using compressed air to blow it clean.
good thought, but i removed check valve when in ran new fuel supply hose and electric boost pump.
   / john deere 5420 fuel injection pump #4
..did you reinstall it or did you leave it out?
I left it out since I had a pump to get fuel to the factory filter.
   / john deere 5420 fuel injection pump #7
Can u hear the shut off solenoid clicking when you turn the key on.??
And does it have some electrical wires coming off the bottom of the pump .??
The solenoid is getting power at key on but i don't hear much any more. I will get a non hearing impaired person to listen for me and report back. no wires on bottom of pump.
I removed wire from pump and turned on switch. touching wire end to pump terminal makes a spark but no sound or feel a bump.
What would this take to repair? The solenoid was working when the pump was removed last year. I rebuilt the pump in my 301a ,
I feel ok about taking this on apart.
   / john deere 5420 fuel injection pump #10
The solenoid is put in from underneath the top cover..
The cover needs to b removed.. the replacement is self explanatory..
But I feel you’ll find the original problem after removing the cover..(water/rust)
2017 Ford F-450 Crew Cab Knapheide Service Truck (A49461)
2017 Ford F-450...
2008 MACK GRANITE HOT OIL (A50854)
2008 MACK GRANITE...
2002 International 4400 SBA 4x2 Flatbed Truck (A49461)
2002 International...
2014 MACK GU713 WATER TRUCK (A51243)
2014 MACK GU713...
2021 Ford F-250 4x4 Ext. Cab Pickup Truck (A49461)
2021 Ford F-250...
2015 LINDE H80D FORKLIFT (A50854)
2015 LINDE H80D...
