John Deere 54" walk-behind
   / John Deere 54" walk-behind #1
12Bravo
Eastern TN
Kioti CK2610 TLB, Gill 5' Scraper Blade (Tilt/Angle)
Moving on to another project while waiting on Kioti parts.
My wife has this mower that is in need of a LOT of work. Being that is has a 17HP Kawasaki and from my understand this is a good motor.
I've pulled the carb and cleaned it and put it all back together. The jet that's inside the bowl, main jet I think, isn't set correctly. I'm having trouble finding this setting.
Would anyone know how far this jet needs to be screwed in or backed out?
I didn't take the carb apart or I would of counted where it was set.
Part number for carb that's on it is: AM122852
   / John Deere 54" walk-behind #2
In the stem? The main jet is turned in all the way- snug, no adjustment.
   / John Deere 54" walk-behind #3
I'm with tp.
Generally, jets go snug, a needle (to go in a jet or other orifice) may adjust.
Thank you
I wasn't sure
I got a spring for the throttle return, so hopefully this think will run right.
Thanks again
   / John Deere 54" walk-behind #5
Usually the jets are screwed in tight. Does it have a float? Often the float has a setting for it, sometimes a certain sized drill bit under the float with the carb upside down.
It has a float, I snugged it up and will have the new throttle spring on tomorrow and see how it goes.
BANDIT ZT1844 RUBBER TRACK STUMP GRINDER (A50458)
BANDIT ZT1844...
BUSH HOG 32601 - 6' ROTARY MOWER (A51243)
BUSH HOG 32601 -...
2015 Chevrolet Tahoe SUV (A50324)
2015 Chevrolet...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A49461)
2019 Allmand...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
1968 International Harvester 856D 2WD Tractor (A50657)
1968 International...
