Oil & Fuel John Deere 5325 won't start
   / John Deere 5325 won't start #11
The fuel lines on my 5520 started to rot and began to get "gooey" and collapse on themselves. I had to replace them all but it wasn't that difficult. I could see where that could be a problem to check out.
   / John Deere 5325 won't start #12
If your 5325 is a STRADDLE MOUNT or ISOLATED OPEN OPERATOR STATION / CAB go to the parts catalog and look up this part number RE220719 it is a inline fuel filter/strainer in the fuel line.
   / John Deere 5325 won't start #13
Very good. It's been a while since I did mine but I do remember an inline filter. Great advice JD5210.
I looked over the diagrams and it looks like there is an inline filter in a line leading from the fuel tank. The maintenance book shows a drain on the fuel tank that can be used to drain some of the tank water and sediment. I will do that and change the filter if I can find where it is and see how that works. You guys are the best!!! Thanks!!
   / John Deere 5325 won't start #15
This is a new tractor to me bought with 1700 hours on the clock. It had been sitting for a while before I bought it this summer. I have filled the tank up a couple of times. I can't even see where the injectors are but I am working on it. I don't know if there is a down stream bleeder but there is fuel coming out of the fuel filter bleeder and I did fill the filter with fuel prior to putting it on and bleeding it. I want to thank you all for the help. Keep it coming. Today it's 10 degrees F. with 2 feet of snow on the ground. Won't be spending too much time on it today.
It looks like your machine is a 5 cylinder, you will have 5 lines going into the engine, ( think of spark plugs), loosen one of them while starting, you should see fuel coming out after air has been expelled.
   / John Deere 5325 won't start #16
   / John Deere 5325 won't start #17
The fuel is gelled or your fuel line screens are plugged. It gelled in our tractor at 25 F because they hadn't changed to winter fuel, needless to say i was pretty ticked off I couldn't use my tractor.
UNUSED RAYSKY RM87-96 MOBILE TOILET SHOWER (A57193)
UNUSED RAYSKY...
2016 Chevrolet Tahoe SUV (A56859)
2016 Chevrolet...
CURT MANUFACTRING 1280# SQUARE JACK (A57192)
CURT MANUFACTRING...
1995 John Deere 7400 (A53317)
1995 John Deere...
PALLET OF KUBOTA L3902 HOOD, DASH (A57192)
PALLET OF KUBOTA...
2017 Ford F250 (A55973)
2017 Ford F250...
