john deere 5325 with 542 loader lift capacity
   / john deere 5325 with 542 loader lift capacity #1
kybeeman
Alexandria KY
John Deere 5325
I have a John Deere 5325 with a john deere 542 loader. I am trying to find the lifting capacity for it. I need to lift a 2300 pound outdoor wood furnace off a flat bed truck that is 4 ft high. The dealer said my loader will have to lift 12 feet. Does anyone know if I will be able to lift it?
   / john deere 5325 with 542 loader lift capacity #2
542 loader specs says little over 4,000 lbs at pivot lifted 59" above ground, 2,900 lbs 800mm ahead of pivot at same height.
Have plenty of ballast and weight on the 3pt for counter weight and you should be ok.
   / john deere 5325 with 542 loader lift capacity #3
3,000 lbs at pivot and 2,100 lbs 800mm in front of pivot at full height , which is 128"
2016 J&M 1122-20T X-Tended Grain Cart (A50657)
2016 J&M 1122-20T...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
Grundfos Centrifugal Pump (A50121)
Grundfos...
Pallet of PTO Shafts & Hydraulic Cylinders (A50121)
Pallet of PTO...
2014 Chevrolet Equinox SUV (A50324)
2014 Chevrolet...
