John deere 5210 with 520 loader leaking at lift arms
   / John deere 5210 with 520 loader leaking at lift arms #1
NRXTM
katy
John Deere 5210
I just bought a john deere 5210 with a 520 loader and I found a hydraulic leak at the lift arm on one side. How can I fix this? Is there any way to take it off and replace the seal? Thank you
   / John deere 5210 with 520 loader leaking at lift arms #2
JD makes a kit to replace the seals. I have supplied a link to JD parts catalog or call your dealer. I have never taken one a part, so if it was me I would see if there are videos to watch and call your local JD dealer to get a cost. Did you get the parking stands for the loader as you will need them, if you want to take off the loader, often these get taken off and later do not get sold with the loader.
I have included a few other links, loader and tractor operator manuals.
John Deere - Parts Catalog
http://manuals.deere.com/omview/OMW44993_19/
http://manuals.deere.com/omview/OMRE71736_19/
Here are some other links you may find of interest.
Leaking Fuel Cap : Solve a leaky fuel cap on some older 5000 series tractors
Loose Muffler on Some 5000 Tractors : Quick fix for loose mufflers or exhaust leaks on certain 5000 series tractors.
http://www.deere.com/en_US/ag/servicesupport/tips/augusta/5000/instrpanelfog.html
http://www.deere.com/en_US/ag/servicesupport/tips/augusta/5000/tiretips.html
http://www.deere.com/en_US/ag/servicesupport/tips/augusta/5000/clutchslip.html
http://www.deere.com/en_US/ag/servicesupport/tips/augusta/5000/trancreep.html
http://www.deere.com/en_US/ag/servicesupport/tips/augusta/5000/timingrod.html
http://www.deere.com/en_US/ag/servi...hanical-front-wheel-drive-tire-recommend.html
http://www.deere.com/en_US/ag/servicesupport/tips/augusta/5000/modelyear.html
http://www.deere.com/en_US/ag/servicesupport/tips/augusta/5000/bentcylinderrods.html
http://www.deere.com/en_US/ag/servicesupport/tips/augusta/5000/backlash.html
Thank you for all the info
   / John deere 5210 with 520 loader leaking at lift arms #4
I just had one done on my 512 loader which would be similar. Cost me 150.00 at the dealer.
I don't have any john Deere dealers near me but I do have a kubota and new holland dealer close to me, would they fix it also ?
   / John deere 5210 with 520 loader leaking at lift arms #6
Without a local Deere dealer, there a few options.
Take the cylinder to a hydraulic shop. They will be able to replace the seal (s) the leaking rod seal and the piston seal. Do both since the cylinder will be apart.
Order the parts from Deere (Google Greenfarmparts.com) and do it your self. Be aware that getting the nut off the piston can be troublesome.
   / John deere 5210 with 520 loader leaking at lift arms #7
Is it leaking bad enough to require a fix? I can't really tell from the pictures.
   / John deere 5210 with 520 loader leaking at lift arms #8
I just had a FEL cylinder on my M4700 rebuilt locally
434820d1438266573-john-deere-5210-520-loader-20150711_074553-jpg
Cost $45.
Not sure how much is bad, this is my first tractor but its about 1/4 to half a cup a day
Ok Ill look around for a shop, thanks
2023 JACTO ARBUS-1000 LOT NUMBER 69 (A53084)
2023 JACTO...
New Wolverine 3pt Receiver Hitch (A53002)
New Wolverine 3pt...
JOHN DEERE TX LOT NUMBER 152 (A53084)
JOHN DEERE TX LOT...
Toro ProCore 864 Series 64in Turf Aerator Tractor Attachment (A51691)
Toro ProCore 864...
2021 ALLMAND BROS, INC. NIGHT LITE LIGHT TOWER (A52472)
2021 ALLMAND BROS...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
