John Deere 5205 Will not start.
   / John Deere 5205 Will not start.
Thank you. The battery terminals are tight and clean.What ever it is when i put a multimeter on the key switch fuse slot. It shows one side of the slot to a dead ground. Thanks I will keep looking.
   / John Deere 5205 Will not start. #12
Bassmat, shoot me your email, i have a PDF of the tech manual you're welcome to
Joe
Can I get a copy? Helping a neighbor with a no start head scratcher, tech manual would be a huge help! Email is Rpottsl@att.net
   / John Deere 5205 Will not start. #13
Bassmat, you seem to have a good knowledge of testing,
if tha diagram provided by JD5210 is correct, remove the fuse for the "fuel shut off solenoid",
then test the " ignition side of the fuse" for a short to ground, if this doesn't short to ground, then you know your problem is on the other side of the fuse, The wire to the solenoid relay or to the solenoid on the pump itself. You can then disconnect the solenoid on the pump and do your test for a ground "again",
this will eliminate the solenoid on the pump. do the same for the relay, my guess is thats it a grounded wire in that circuit that has lost some of its insulation, been there, done that.
Good luck
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A51039)
NEW 2025 Load...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2015 DODGE RAM...
LOT LOCATIONS (A51219)
2013 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A51039)
2013 Doyle Dry...
CM Trucks Utility Bed (A49461)
CM Trucks Utility...
