john deere 5205 PTO hard to engage and disengage
   / john deere 5205 PTO hard to engage and disengage #1
Trickey
Altha, FL
John Deere 5205 diesel
PTO is very hard to engage and once i get it engaged i have to jam it in place with a stick or something to keep it from jumping out of engagement
   / john deere 5205 PTO hard to engage and disengage #2
Not sure whether the problem is that the control lever becomes disengaged, or the implement disengages from the PTO shaft. If the latter, the implement should lock onto the PTO shaft, but (1) you need to align the grooves on the shaft and on the implement by turning one a little bit, and (2) as you push the implement onto the PTO shaft you need to pull the locking ring on the implement shaft toward the rear. Pushing forward at the same time you are pulling the locking ring back isn't easy, but when the implement shaft is in place, you should hear a click.
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A52377)
12-Wheel Pneumatic...
City of Buckhannon - 2005 Volvo Garbage Truck (A52384)
City of Buckhannon...
2016 John Deere 7210R MFWD Tractor (A53342)
2016 John Deere...
WOODS DHS48N LOT NUMBER 75 (A53084)
WOODS DHS48N LOT...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2018 INTERNATIONAL 4400 4X2 EXT CAB SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
