john deere 5205 PTO hard to engage and disengage
   / john deere 5205 PTO hard to engage and disengage #1
Trickey
Altha, FL
John Deere 5205 diesel
PTO is very hard to engage and once i get it engaged i have to jam it in place with a stick or something to keep it from jumping out of engagement
   / john deere 5205 PTO hard to engage and disengage #2
Not sure whether the problem is that the control lever becomes disengaged, or the implement disengages from the PTO shaft. If the latter, the implement should lock onto the PTO shaft, but (1) you need to align the grooves on the shaft and on the implement by turning one a little bit, and (2) as you push the implement onto the PTO shaft you need to pull the locking ring on the implement shaft toward the rear. Pushing forward at the same time you are pulling the locking ring back isn't easy, but when the implement shaft is in place, you should hear a click.
2017 SKY TRAK 6036 TELEHANDLER (A52576)
2017 SKY TRAK 6036...
2017 Mower Max Flexwing Mower (A51573)
2017 Mower Max...
Killbros 260 Seed Conveyor (A52748)
Killbros 260 Seed...
2015 FREIGHTLINER CASCADIA(INOPERABLE) (A52472)
2015 FREIGHTLINER...
Fifth wheel multi use trailer. (A52748)
Fifth wheel multi...
2018 FORD TRANSIT T250 CARGO VAN (A52577)
2018 FORD TRANSIT...
