John Deere 5205 bucket won't tilt
   / John Deere 5205 bucket won't tilt #1
Laerry80
John Deere 5205
If I swap the hoses the bucket tils but then the lift does not work,
   / John Deere 5205 bucket won't tilt #2
When it "doesn't work" -- What happens? Do the hydraulics load up and lug the engine down? Is there absolutely NO movement at all from the cylinders connected to that valve spool? No hose flex or sounds of any kind? Give us something to work with here.
   / John Deere 5205 bucket won't tilt #3
I would suspect a faulty quick disconnect but like Harry states need a little more information.
Bucket goes up and down, but will not tilt. WHen I switch then hoses the bucket tilts but will not raise and lower, When I move the joy stick I can see the hoses flex and I hean a moan from the system. I replaced 2 of the quick couplers and no change. tractor runs fine, when I have the disconnects out, I can use the joystick to see the valve move back and forth in the control block. It acts like there is a block. This happened when I was piling up brush, I lowered the bucket, pushed some brush and it would not move after that, raises and lowers fine. Hope this helps!
   / John Deere 5205 bucket won't tilt #5
I agree it "acts like there's a block". MOST likely one of the quick couplers in my opinion. Since they're most likely all the same, I would trade places with one pair at a time (between the tilt spool and the lift spool) an see what affect that has on the situation.
   / John Deere 5205 bucket won't tilt #6
Watch the hoses closely when movement stops. If both hoses to curl & dump stiffen the problem is in return side of circuit. I.e. if won’t dump then on rod side quick disconnect. Either half can fail on quick disconnects.
I put in my post that I had traded the hoses and what happened. THen bucket tilts, but then it wont raise and lower
How do I fix it?
   / John Deere 5205 bucket won't tilt #9
I saw the point about switching hoses. What I suggested was actually removing and switching some of the couplers. You know that switching functions between valve spools makes a difference. Changing the couplers but keeping the hoses in the same order should tell you something.
I have switched couplers and replaced two of them, switching couplers did not change anything. All the hoses have fluid in them when I push the release fluid runs out. As near as I can tell, the problem is in the return system. I loosened the connections to the control valve and they all have fluid in them. Any other Ideas?
2025 Swict 72in Bucket Skid Steer Attachment (A49346)
2025 Swict 72in...
2008 Chevrolet Colorado Ext. Cab 4x4 Pickup Truck (A48081)
2008 Chevrolet...
CougarLift XLT-SP10 10ft Aerial Lift (A49346)
CougarLift...
Bottle Storage Rack (A50860)
Bottle Storage...
2006 Honda CR-V LX SUV (A48082)
2006 Honda CR-V LX...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A48081)
2000 Thomas Built...
