Mowing John Deere 5103 with John Deere 609 cutter
   / John Deere 5103 with John Deere 609 cutter #1
WARTIGER45
Auburn
John Deere 5103
I have a 2004 John Deere 5103, it's a 50hp tractor and I was seeing anyone and everyone's opinion on running a John Deere 609 rotary cutter behind it, which is a 6' heavy duty. I have recently acquired the cutter but have had the tractor for a while running a mid-duty 5' rotary cutter. As I cut with the JD 609 I can notice when I hit thick spots in grass as opposed to not feeling much different with the 5'. It is not a drastic difference but in some cases where the grass was super thick it would drop about 100 rpms (2200 to 2100 rpms) but if I have the rpms at 2300 it cuts a lot better.
So here is my question:
- is a JD 5103 strong enough to use the JD609 without putting it under too much strain?
   / John Deere 5103 with John Deere 609 cutter #2
You've got the power to run that cutter and a big enough tractor to handle the weight. I don't see a problem.
   / John Deere 5103 with John Deere 609 cutter #3
I've operated a JD 709 on a JD 2040(40 hp) & a Kubota M4900(45 hp) so you should be "good to go"
   / John Deere 5103 with John Deere 609 cutter #4
It all has to do with proper speed for the conditions . I run a 6 ft heavy duty bush hog and have to slow down at times when running into some heavy hay with over 50 pto hp. it is no big deal to so . You should have no problem .
   / John Deere 5103 with John Deere 609 cutter #5
The power drop could be caused by a difference in the condition of the two different mowers cutting blade edges. The tractor itself is plenty big enough.
378587 (A51573)
378587 (A51573)
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
2007 PETERBILT 379 MID-ROOF SLEEPER (A52472)
2007 PETERBILT 379...
GS-3246 MAN LIFT (A52472)
GS-3246 MAN LIFT...
2005 IH 7600 t/a Dump Truck (A52384)
2005 IH 7600 t/a...
2016 GMC Sierra Pickup Truck, VIN # 1GTN1LEC5GZ901362 (A51572)
2016 GMC Sierra...
