Mowing John Deere 5103 with John Deere 609 cutter
   / John Deere 5103 with John Deere 609 cutter #1
WARTIGER45
Auburn
John Deere 5103
I have a 2004 John Deere 5103, it's a 50hp tractor and I was seeing anyone and everyone's opinion on running a John Deere 609 rotary cutter behind it, which is a 6' heavy duty. I have recently acquired the cutter but have had the tractor for a while running a mid-duty 5' rotary cutter. As I cut with the JD 609 I can notice when I hit thick spots in grass as opposed to not feeling much different with the 5'. It is not a drastic difference but in some cases where the grass was super thick it would drop about 100 rpms (2200 to 2100 rpms) but if I have the rpms at 2300 it cuts a lot better.
So here is my question:
- is a JD 5103 strong enough to use the JD609 without putting it under too much strain?
   / John Deere 5103 with John Deere 609 cutter #2
You've got the power to run that cutter and a big enough tractor to handle the weight. I don't see a problem.
   / John Deere 5103 with John Deere 609 cutter #3
I've operated a JD 709 on a JD 2040(40 hp) & a Kubota M4900(45 hp) so you should be "good to go"
   / John Deere 5103 with John Deere 609 cutter #4
It all has to do with proper speed for the conditions . I run a 6 ft heavy duty bush hog and have to slow down at times when running into some heavy hay with over 50 pto hp. it is no big deal to so . You should have no problem .
   / John Deere 5103 with John Deere 609 cutter #5
The power drop could be caused by a difference in the condition of the two different mowers cutting blade edges. The tractor itself is plenty big enough.
2014 Deere 304K (A50120)
2014 Deere 304K...
Mahindra 2516 Compact Tractor w/Loader (RUNS) (A50774)
Mahindra 2516...
King Kutter Rotary Tiller Tractor Attachment (A51691)
King Kutter Rotary...
2008 Ford F-250 Ext. Cab Pickup Truck (A50323)
2008 Ford F-250...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A52748)
NEW HOLLAND 706 30...
Topcat Skidloader Articulating Mower (A50774)
Topcat Skidloader...
