john deere 5103 vs kubota m4800
   / john deere 5103 vs kubota m4800 #1
whitearrow
philadelphia,ms
john deere 5203
whatup fellas? i am in the market for a new 50 engine,44 pto hp range tractor.these two are the ones that i like and are in my price range.my main concern is reliability,durability.i like certain aspects of both machines.the kubota's engine is smoother,but i like the way that the jd's gear shifters are located.someone please help.
whitearrow->>>-------------------->
   / john deere 5103 vs kubota m4800 #2
Welcome to Tractorbynet.
But you asked a question for which a valid answer is impossible. /forums/images/graemlins/wink.gif They're both good tractors, but obviously the best one is the one you like best. And if you can't decide which one that is, then it's the one that comes from the dealer you like best. And if all else fails, what color does your wife prefer? /forums/images/graemlins/wink.gif
In any case, good luck with your shopping.
   / john deere 5103 vs kubota m4800 #3
When we looked at tractors we ran into the same issue with the gearshift lever location Kubota chose. To put it bluntly, it looked old fashioned and kind of silly. It was the one, major thing I didn't like about the Kubota. But we still went with it.
Now that we've run the Kubota for 60 some odd hours, the location doesn't bother me. It is very easy and intuitive to use the gearshift. Ours is a M6800, so the cockpit might be a tiny bit bigger then the M4800. I'm also short (5' 6"), so I have the seat moved up a bit.
Getting on and off the tractor is very easy as long as the gearshift lever is in neutral. If it is in gear, my leg will bump the lever on the way out (it never touches it when it is in neutral). I think of it as a safety device. If I put the shuttle shift in neutral to stop the tractor, set the brake, and then try to dismount while the gear shift is still in gear, my shin will bump the lever. I sit back down and put that in neutral too. Most times, I'll also put the high/low range selector in neutral.
I don't wanna get run over!
Try mounting and dismounting the M4800 a dozen times. If you find that gearshift lever to be too big a pain, then the John Deere will be a better fit. Both are great tractors, you just need to figure out which one will fit YOU best.
2013 Vermeer V800G T/A Towable Vacuum Trailer (A50322)
2013 Vermeer V800G...
John Deere 652R (A50121)
John Deere 652R...
2020 Cat 299D3XE Skidloader (RIDE AND DRIVE) (A50774)
2020 Cat 299D3XE...
Bobcat T650 Skidloader (BURNT) (A50774)
Bobcat T650...
2004 Stage Line SL-250 Mobile Folding Stage Trailer (A50322)
2004 Stage Line...
KJ 10' Galvalume Corrugated Steel Panals (A50121)
KJ 10' Galvalume...
