john deere 5065e vs ?
/ john deere 5065e vs ? #1
walton farmer
loganville ga
John deere 5065e
Hello everyone I am new to the site and am looking for advise.I am going to purchase first tractor at the end of the year and need some help making educated descion. I have been looking at the deere 5065e I would like to know if this will handle my needs and how much price difference b etween other makes in this class. I will be using the tractor to bush hog plow bale and move hay mainly bush hogging and food plots but I own 20 to 30 head of beef at any giving time of the year I would like to be able to bale 150 rolls of hay per year for my own cows with a little to spare also I do not have a baler yet so I can pick the right one for the tractor I decide on any advice would be helpful I don't want to short myself of tractor but do not want to spend more than I need to
/ john deere 5065e vs ? #2
you would prolly be better suited to get an 85hp tractor for all your wanting todo.that way you could pull a 4 by 6 baler with ease.about all the 5065 could pull is a 4 by 5 baler.
/ john deere 5065e vs ? #3
I use the Kubota M7040(now a M7060) to pull my 4x5baler,12ft bushhog and daily cattle operations and I wouldnt wont to go any smaller than the 64pto HP. The 85HP bigbull mentioned would be a great option if the pocket book would allow and wouldnt be over kill by any means. Level fields mine works great,even with small grades its not bad but I couldnt see going any smaller,and many times in a rush would like more HP but the new M7060 has a 12x12 better gear selection. With loaded rears it moves round bales great,the one without not unless got one on the back. I use a 3point 8ft hay cutter and dont have to run my loader but anything bigger without a caddy I would see needing it on. Can you make due with a 5065,im sure you could but I have made the costly mistake of having to do it twice,to get the one should have in the first place. I bale around 150 to 200 bales a year,own/lease 500+acres(100 being hay ground),at the moment 54head cows&2 Bulls and if only had to work with one tractor instead of the two 7040s,it would be atleast a 85+HP. JohnDeere 5083/5093e, Kubota M8560/9960 ,Mahindra 8560/100p , NH Powerstar 4.85/4.95 something along those lines. M100GX is what I wont...
Thanks for the input I will continue my quest since I have a few more months before I will be able to make a deal on one does anyone know if john deere or kubota will offer 0 percent financing for 2014.
/ john deere 5065e vs ? #5
What my dealer has been recommending is the 5093e for general baling needs. It also depends on your baler.
/ john deere 5065e vs ? #6
Agreed. I would look at a 5083E or 5093E. If your budget can stand it, the 5M series is a nice upgrade to the 5E.
That 63hp would be in a bind. 80+ hp will handle a 4x5 or 4x6 with ease.
Just so you'll be aware of it, the JD is a much heavier machine than the Kubota. Makes hay handling easier without having to add rear ballast.
IMHO, the best round balers are JD and Vermeer. In that order. And, my opinion, plus 50 cents might get you a half cup of coffee, in some places. :D
BTW, :welcome: to the forum.
/ john deere 5065e vs ? #7
we are pulling a 567 jd baler with a jx80 4x4 rops case.an its bigger in size but not really in hp compared to my 7040.
/ john deere 5065e vs ? #8
You hardly ever hear anyone say that they wish they had less horsepower.
/ john deere 5065e vs ? #9
JD 5083e-7200lbs-83/69pto HP
Kubota 8560-6680lbs-85/76pto HP
Mahindra 8560-8122lbs-85/70pto HP
That's 4x4 cab tractors the Kubota 7060 is 5380lbs-71/64pto HP,couldnt find any numbers on the new 5075e cab or powerstars.
/ john deere 5065e vs ? #10
Exactly the route I went. 5093e running a deere 567 baler. Great all around tractor for us "small" farmers. I put up ~100 bales a year.
/ john deere 5065e vs ? #11
According to Deere's website, the 5083e MFWD with cab weighs 7385 lbs. That's a ton heavier than the Kubota.
BTW, the 5085M is even heavier, it's 8000#.
My NH TN70A (current model is a T4030) MFWD open station tractor weighs about 1000# more than the Kubota with the cab. And, that weight makes a difference, especially using the FEL.
/ john deere 5065e vs ? #12
Those numbers came off tractordata
/ john deere 5065e vs ? #13
TractorData is a good, quick reference, and I use it myself. It is, however, sometimes just a tad inaccurate or incomplete.
It's close. But close only counts in horse shoes, hand grenades, and slow dancing. :laughing:
/ john deere 5065e vs ? #14
I can tell you for sure that the Mahindra 8560 is heavy,I have hauled my brother and you can really tell its got some weight,especially with tires loaded,over my 7040
I have always wondered why Deeres hp gap between engine and pto is lower than others
2003 International 4300 Flatbed Dump (A62613)
2003 International...
2019 Ford F450 Extra Cab 4x4 Service Crane (A62613)
2019 Ford F450...
2017 Bobcat E55 (A60462)
2017 Bobcat E55...
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
2022 EZ-GO ELITE...
2016 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61573)
2016 Chevrolet...
