John deere 5055d gauge issues
   / John deere 5055d gauge issues #1
dw grigg
avery tx
john deere 5055d
my 4 year old 5055d is doing the following
at idle fuel gauge read normal, when you increase rpms it falls back to empty, and coolant gauge will only go to the left edge of the green and no more. both use to work.
I have cleaned area where ground wire is attached with no change
any ideas?
   / John deere 5055d gauge issues #2
any ideas?
Do you have a wiring diagram in the owner's manual which you could post?
Dave M7040
   / John deere 5055d gauge issues #4
Have you cleaned the ground where the negative battery cable connects to the frame? Clean the bolt, the hole it screws into and the cable. When I purchased my 5210 the coolant needle jump around and this is how I fixed it.
Both fuel and coolant sensors are variable resistor (potentiometer). There output is measured in ohms.
Resistance of potentiometer on gauge sensing circuit controls the fuel level shown on gauge. As float moves up or down with changes in fuel level, electrical resistance of potentiometer changes accordingly. When tank is full, resistance is low and gauge needle moves to full position. When tank is empty, resistance is high, and gauge needle moves to empty position. Potentiometer resistance between
these two positions varies in direct proportion to changes in fuel level. This allows gauge to accurately
display quantity of fuel in tank regardless of its level.
Temperature sender is a variable resistor that responds to changes in coolant temperature. Low
coolant temperatures cause high resistance. High temperatures cause low resistance.
Fuel full low resistance/ empty high resistance
Cool high temp low resistance / low temp high resistance
In both cases you are increasing the resistance as you stated.
Here are the steps I would take disconnect either the fuel or coolant sensor wire at the sensor. Take an ohm reading with the engine at idle. Then increase the rpms and take another reading. Note the color of the wire and the number on the wire. Plug the sensor back in. Now remove the plug from the back of the cluster and repeat the ohm test. Using the ground for the cluster and grounding to the frame/engine.
Let us know what you find out.
thanks for the info, I did clean the ground cable from the battery where it grounds to the frame, I built instrument panels for military use for years and I am fairly knowledgeable on gauge testing and I do appreciate the info. since both gauges are acting up to me its still looking like a grounding issue and before I start tearing into the dash I am trying to find out where the dash cluster ground is located so I can clean it first. I wonder if I remove the panel below the steering wheel where the ignition is located if it will be in that area, any ideas?
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2020 Prime Time Avenger ATI 26BK 28ft. T/A Travel Trailer (A55853)
2020 Prime Time...
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2008 INTERNATIONAL...
2020 Chevrolet Silverado 1500 (A55315)
2020 Chevrolet...
60" HYD BRUSH CUTTER (A52706)
60" HYD BRUSH...
