john deere 5055 D hydraulics
/ john deere 5055 D hydraulics #1
coonster62
Lovelady Texas
steering started getting sticky ,brake pedal started going down further , lift got noisier ...started hearing knocking under hood , when i put my hand on the hydraulic pump i could feel the knocks...is the pump just going out? or has my fluid got contaminated or something else?
/ john deere 5055 D hydraulics #2
I don't have a clue, but....
..the "knocks" is a bit unsettling.
1. Is there plenty of hydraulic oil in it?
2. Are you sure there's no water/ice (now that temps are colder) in the hydraulic oil? These tractors often get a tear at the bottom of the rubber boots at the bottom of the shifting levers that can let water get into rear end.
3. Could knocks be a relief valve cycling? I've read that these tractors also have a reputation (because of misadjusted linkage? -not sure) that when the 3 point hitch lever is at fully raised, the 3pth can try to keep raising and the hydraulics go into relief. In some cases this has caused things to get so hot the fuel tank melts.
/ john deere 5055 D hydraulics #3
Welcome to TBN
Have you changed hyd filter lately & checked to determine if hyd oil is at the full mark?
2012 PREMIER 4NNT PORTABLE PUMP (A63276)
2012 PREMIER 4NNT...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
24 Gauge R Panels (A65640)
24 Gauge R Panels...
2023 Stearling Trailer (A60352)
2023 Stearling...
Wood Fence Post (A62613)
Wood Fence Post...
2001 Freightliner FL70 Day Cab Truck, VIN # 1FUBBUAK21HJ24793 (A65563)
2001 Freightliner...
