John Deere 500c Backhoe fuel in oil after sitting.
   / John Deere 500c Backhoe fuel in oil after sitting.
Fuel line shut-off valve if operating correctly should stop fuel from entering engine crankcase while engine is setting idle IE not operating BUT valve will have no affect on the problem while engine is operating. In today's world of "almost right parts" I would be checking transfer pump to determine if it was the cause of fuel in crankcase. Another option is just disconnecting fuel transfer pump & installing an electric fuel in it's place. If it wasn't the cause then R&R umbrella seals on inj pump shaft. You definitely don't want engine oil thinned by diesel destroying your engines crankshaft bearings!!!!!!!!!
100% thanks TX Jim! Will be digging into this soon!
   / John Deere 500c Backhoe fuel in oil after sitting. #12
You're welcome
   / John Deere 500c Backhoe fuel in oil after sitting. #13
Any chance you're filling the tank so full that diesel is flowing up the return line to the injectors? I don't believe there is any check valve on that line. Sure makes for an easy fix...
Nope, that sure would have been nice and simple.
72" Hydraulic Broom  (A52384)
72" Hydraulic...
2022 John Deere RD35F Draper Head (A53342)
2022 John Deere...
2006 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A51247)
2006 FORD F750 XLT...
2007 International 7500 sba Flatbed 6x6 Truck (A52384)
2007 International...
SKYJACK SJIII 3226 ELECTRIC SCISSOR LIFT (A51246)
SKYJACK SJIII 3226...
PALLET OF PORTABLE AC UNITS (A51248)
PALLET OF PORTABLE...
