John Deere 48 or 54 inch deck ?
   / John Deere 48 or 54 inch deck ? #1
Rebs
Niagara Falls, NY
JD 175
Does one or the other of these decks perform better as far as throwing out the grass clipping and not leaving them in a row ?
   / John Deere 48 or 54 inch deck ? #2
I've got a 54" on a GX345 and in tall grass as long as you keep the grass chute open it throws pretty good. I keep that chute open with a bungee cord because I mow around lots of rocks and trees and just makes it easier...
   / John Deere 48 or 54 inch deck ? #3
I've got the 54 deck on my La175 Deere I can't imagine going back to a smaller deck, my neighbor has a 48 and he is very fond of the 54.
However his 48 deck is powered by 18hp compared with my 24hp, it takes a lot to bog it down .
   / John Deere 48 or 54 inch deck ? #4
I had a very old JD 332 with 54" deck and it really threw the clippings out a long way. NO windrow on that one even with the chute down.
   / John Deere 48 or 54 inch deck ? #5
Try to go for the 54" as those 6 inches add up after a few hours of cutting.
   / John Deere 48 or 54 inch deck ? #6
I use a 48" because I can't fit the 54" deck everywhere I need to go. If you have the clearance I would go with the wider deck.
2013 Freightliner 122SD Day Cab Truck, VIN # 1FUJGNDR3DDBZ7701 (A54865)
2013 Freightliner...
2012 CATERPILLAR 279C2 SKID STEER (A51242)
2012 CATERPILLAR...
UNUSED 70PCS Black Metal Roof Panels (A53117)
UNUSED 70PCS Black...
70pc 12ft.x 3ft. Grey Metal Roof Panels (A53424)
70pc 12ft.x 3ft...
AUCTION STARTS HERE @ 9AM (A52705)
AUCTION STARTS...
New/Unused Easy Clean Hot Water Pressure Washer (A54865)
New/Unused Easy...
