John Deere 4600 hydro questions
   / John Deere 4600 hydro questions #1
sqdqo
Marquette Michigan
Massey Ferguson 492 w/Quicke Q750 loader
I have a JD 4600 hydro unit. A couple questions if anyone could offer advice or opinion.
When idling and an attachment is on the 3 point with it raised the 3 point is constantly losing pressure and correcting itself. What kind of job is it to repack or repair the hydraulics so it maintains level better. Or is it not worth repairing and just leave alone?
Also when idling fairly fast and in gear but foot not on forward or reverse pedal the machine will bump or move slightly like enough hydraulic is leaking to move it. What is causing this? Is there an adjustment or repair? How involved is it?
   / John Deere 4600 hydro questions #2
Probably both are adjustments that can be made, the least being not worrying about it when idling. ;)
Do you have the tech manual? There are troubleshooting suggestions and adjustments that can be made.
Does the 3 ph leak down when the tractor is off, and how fast if it does?
   / John Deere 4600 hydro questions #3
How many hours on the 4600? Are you the original owner?
I'd spend the money and get the tech manual on CD as it's half the cost of the paper one and you can print out replacement pages as required when previous copies get torn and greasy.
The tech manual is worth the money. I have one for my 4200.
Getting at the 3-point lift cylinder is not going to be fun, and you'll need a helper (human or engine crane) to get the cover off.
Hopefully it just needs a couple of adjustments.
https://techpubs.deere.com/
machine has 644 hrs. The 3pt lift cylinder leaks down completely overnight, I have never timed it.
2000 SPARTAN SUMMIT RV (A50854)
2000 SPARTAN...
2018 Caterpillar 416F2 4x4 Extendahoe Loader Backhoe (A50322)
2018 Caterpillar...
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A49461)
2019 Generac...
2004 Dodge Dakota Ext. Cab Pickup Truck (A50323)
2004 Dodge Dakota...
2016 LINK-BELT 235X3 SPIN ACE EXCAVATOR (A50854)
2016 LINK-BELT...
2020 INTERNATIONAL LONESTAR TANDEM AXLE SLEEPER (A51222)
2020 INTERNATIONAL...
