john deere 455 glow plugs not working
   / john deere 455 glow plugs not working #1
andrew1346
john deere 455
My glow plugs are not working, the light on the dash comes on. But there is no voltage at the plugs...Looks like there is a control board on the left side of the dash. Parts book says it is a glow plug control. Kinda expensive to just throw parts at it at this point...Does anybody have any other ideas? There is a relay, it says its a engine temperature relay, not sure what its purpose it though. Or a wiring diagram maybe?? Thanks
   / john deere 455 glow plugs not working #2
What is the serial number? There is a break at 70,000. Here is below test procedure and test points. Also wiring diagram too, if needed.
Looks like my module is dead. Power going in, nothing going out...Thanks for the help!!
Do you know what the relay on the right side above the little fuse panel is for by chance? I could not get it to do anything either...Parts sheet says engine temperature..
   / john deere 455 glow plugs not working #4
Above or below the 70,000 s/n break?
serial # 30279
   / john deere 455 glow plugs not working #6
I believe this sketch shows that it is the engine high temp relay. I'm not sure if it senses how cold it is so the glow plugs stay on longer, or just senses when the temp is above 100 deg and disengages the glow plug routine, or something else.
I'll post the theory of operation written up on the glow plug of the 455
Thanks very much for the info...Looks like I am buying a module, unless I can figure out the problem with the module circuit, I'll monkey around with it a little first, not out anything yet....
The thing that i did notice on your diagram, is that the control module looks different, my doesnt have connectors on it, it has wires soldering into the bottom that are about four inches long with connectors on the ends
   / john deere 455 glow plugs not working #9
Is the glow plug module soldered to the electrical board on left side of dash?
The glow plug control is its own module, located on the left side right behind the radiator. Mine is fried. I replaced the melted fusable links in the harness on the right side of the engine with flat fuses. And wired in a toggle switch to turn on the glow plugs, just hold on the switch for ten to fifteen seconds, and then crank. The module is I think expensive for what it does.
   / john deere 455 glow plugs not working #11
I know this is an old thread, but I think my module might be shot. Does anyone have the schematics for a 70000+ machine?
   / john deere 455 glow plugs not working #12
What part of the schematics are you looking for.. the electrical ?
Same as my previous reply, but for the Over 70000 s/n ?
   / john deere 455 glow plugs not working #13
Yes, please.
   / john deere 455 glow plugs not working #14
Attached here
   / john deere 455 glow plugs not working #15
It shows me me to test connections 11 and 12, but I don't see them on the schematics.
   / john deere 455 glow plugs not working #16
For some reason.. my fault.. the schematics didn't post as I expected. Thought I double checked too, but obviously not.
Try that again.
   / john deere 455 glow plugs not working #17
Great! Thank you.
   / john deere 455 glow plugs not working #18
Try that again.
Beenthere,
Would you happen to have the schmatic for the JD 455 pto circuit and the size of the fuse it takes? Thanks ED.
   / john deere 455 glow plugs not working #19
Serial number, as there is a break between early and late? Above or below 070000?
Also, above or below 031478 ?
   / john deere 455 glow plugs not working #20
Fuses are 15 amp
Still want a schematic? need serial numbers, if yes.
VOLVO SD75B SMOOTH DRUM ROLLER (A60429)
VOLVO SD75B SMOOTH...
2020 SAVANA 3500 16FT BOX TRUCK (A59905)
2020 SAVANA 3500...
Kubota B2301 (A53317)
2006 JAYCO JAYFLIGHT 30' TYPE CAMPER (A58375)
2006 JAYCO...
2018 CATERPILLAR 305E2 CR EXCAVATOR (A60429)
2018 CATERPILLAR...
2015 CASE SV280 SKID STEER (A60429)
2015 CASE SV280...
