John Deere 4520 surges like governor issues
   / John Deere 4520 surges like governor issues #1
Hawbuck
Warrenton, mo
John Deere 4520
My 4520 surges under any load, sometimes worse than others. It seems like the governor is cutting out and back in seconds. It surges about 100 RPM's
   / John Deere 4520 surges like governor issues #2
:welcome: to TBN
Check for good fuel flow from tank to IP. Check to b sure throttle/governor linkage isn't binding.
   / John Deere 4520 surges like governor issues #3
And fuel is good (no algae), and filter is clean.
   / John Deere 4520 surges like governor issues #4
It didn't recently run out of fuel or have a filter change did it? Whenever I ever had lunging on the idle it was due to a small amount of air in the system that was eventually purged out after running it at high RPMs for an extended period.
   / John Deere 4520 surges like governor issues #5
What year was it built? Pre 2009? I'm wondering if it's mechanically governed, or the fully electronically controlled engine.
   / John Deere 4520 surges like governor issues #6
All the >current< 4520 (not the 1960's version) are common rail fuel systems with electronic control. I've heard of the hydros doing this when the loadmatch isn't working right.
   / John Deere 4520 surges like governor issues #7
The pre 2009 ones are mechanically governed. Take a look at JD parts and you will see the different fuel systems and where the serial number break was. When eThrottle was introduced on the 4520's and 4720's is when the change was.
Yes I agree with the Loadmatch. I originally thought the OP was talking about idle, but after re reading I see that it is acting up under load.
3T HYD TILT BUCKET FOR MINI EXCAVATOR (A52708)
3T HYD TILT BUCKET...
1604 (A57192)
1604 (A57192)
(4) CUSTOM PACKING WHEELS W/ 8 LUG RIMS (A52708)
(4) CUSTOM PACKING...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
HYDRAULIC WINCH RACK (A58214)
HYDRAULIC WINCH...
12V 20GPM Gasoline Fuel Transfer Pump (New/Unused) (A59225)
12V 20GPM Gasoline...
