John Deere 45 Combine Part Identification
   / John Deere 45 Combine Part Identification #1
TrenaryDucks
Michigan UP
Agri-Power 5000 (Zetor 5011)
I'm looking at buying an old John Deere 45 Combine. The owner said the bearing on the the reciprocating arm that drives the knife bar needs to be replaced. Attached is a picture of the arm with the missing bearing. What is this bearing called, and any ideas as to the part number? Also, any ideas of where to get a replacement? Thank you.
   / John Deere 45 Combine Part Identification #2
You can look it up at jdparts.deere.com (might have to look under equipment search to find it "Combine")
The missing bearing housing is PK1647H
and the bearing is JD 7143C
BUT,when you check the availability it can't be found,so you will have to ask a dealer?
That is the sickle pitman bearing.
Thank you for the quick and detailed reply.
   / John Deere 45 Combine Part Identification #4
PK1647H shows to be available in Tennessee from Parts Depot but one has to go through a participating dealer to order the part. Brg is available from JD JD7143 Ball Bearing - SINGLE ROW BEARING PNL ADD 25.86 USD if part number is entered correctly.
2021 International HV507 4x4 12ft Single Axle Dump Truck (A51692)
2021 International...
2022 SIDUMP'R 48FT TRI AXLE SIDE DUMP TRAILER (A54607)
2022 SIDUMP'R 48FT...
Honda XR Dirt Bike (A53117)
Honda XR Dirt Bike...
2015 New Holland Boomer 47 4WD Agricultural Utility Tractor (A53421)
2015 New Holland...
ALLISON TRANSMISSION (A53843)
ALLISON...
