John Deere 445 running rough
/ John Deere 445 running rough #1
nfhi1994
John Deere 140
I Have a John Deere 445 that is running rough. Governor, spark plugs, map sensor have all been replaced and tractor still runs rough. Tractor runs better with hose off of map sensor.
/ John Deere 445 running rough #2
:welcome: to TBN
Looks to be a s/n break at 70000. Are you above or under that?
History of fuel, and fuel filters.. or what may have happened when the trouble started.
Reasons for replacing those items you mentioned, may help.
Above that serial number break.
Tractor was brought to me in pieces. I put it back together and returned back to customer. it ran for two days no issues started acting up was able to make it run smooth by holding governor linkage. Thought that governor needed replaced due to that. ( I did adjust governor via tech manual first, nothing changed) i did change the fuel filter, nothing changed. If I pull the hose off of the map sensor it would start to run better. That痴 why I replaced the sensor, no change.
/ John Deere 445 running rough #4
Was the engine disassembled when it came to you?
Any reason given by the customer as to why he/she disassembled the tractor?
/ John Deere 445 running rough #5
try disconnecting the battery for 10 minutes, then retry, that should reset the computer..
Yes the engine was dissasembled. Customer had someone else work on it first. They tore it apart and for what ever reason gave up on it and returned it in pieces.
Customer had new piston rings put in due to engine smoking. That痴 why the engine was disassembled
I tried that and nothing changed still runs rough
Yes I have it did not change anything. if I remove the hose from the map sensor it would run better if I plug the hose back in to the map sensor it would start running rough again.
When running it spits and sputters and keeps dying
I disconnected the battery for 10 minutes. Nothing changed it still runs the same
It happens at all throttle settings.
Will not run longer than 10 seconds.
Idk about what the spark plugs look like, I will hafto see tomorrow when I work on it again.
Left side spark plug is soaked, right side spark plug is dry
I don稚 know why, but the glow plug light keeps randomly flashing.... and I know this doesn稚 have spark plugs
/ John Deere 445 running rough #16
If you have spark plugs then it is either a 425 or 445, the later has EFI. So if you saying this has a glow plug light coming then it must be the 455 which is diesel. So you have confused us all with what you have posted.
It痴 a 445 fuel injected It痴 not diesel
/ John Deere 445 running rough #20
It's time for some basic trouble shooting.
- Check for proper valve gap adjustment
- Check for spark on both plugs
- Remove the throttle body, intake manifold and gaskets
- check for proper fit of gaskets or perhaps even missing gaskets
- Re-install the gaskets, intake manifold and throttle body - make sure that the assembly bolts are torqued properly.
- Check for proper fuel pump pressure
Can you explain this post:
What light is flashing?
What engine is in the machine?
Richard
New/Unused AGT YSRT14 Mini Skid Steer (A65583)
New/Unused AGT...
Parker 500 Auger Wagon (A66285)
Parker 500 Auger...
CATERPILLAR CS44B SMOOTH DRUM ROLLER (A65053)
CATERPILLAR CS44B...
2025 Grapple Mini Excavator Attachment (A61572)
2025 Grapple Mini...
Towable Dual-Line Pipe Road Crossing Trailer (A63689)
Towable Dual-Line...
UNUSED WOLVERINE 6' FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
