John deere 445 hydro leak
   / John deere 445 hydro leak #1
mattsaga
Bismarck, ND
445 John Deere
I recently discovered what seems to be a hydro leak under my 445.
22hp jd with Kawasaki engine with front hyd and pot. With 3pt hitch. Ohd valve. 1700 hours, rebuilt engine.
No symptoms other than a new spot on the floor.
Lemme know if anyone has experience with hyd leaks...
   / John deere 445 hydro leak #2
Can you track it down to at least say where it is originating from?
What is a "pot." abbreviation for ?
How long ago was the rebuild?
   / John deere 445 hydro leak #3
Transmission leaks are pretty common on the 425/445/455. If you are lucky it is the seal on the differential lock shaft which is a black rubber doughnut that pops out of the housing. I have heard that it is possible to reach in there with a long screwdriver and push the seal back in. If you search here and over at mtf you will find several threads about fixing transmission leaks.
Chris
2022 CAT 289D3 (A60462)
2022 CAT 289D3...
PIN PULL AERATOR (A60430)
PIN PULL AERATOR...
UNUSED IRANCH IRLB MINI HYD 4IN1 BUCKET (A60432)
UNUSED IRANCH IRLB...
UNUSED FUTURE QSJ HYD MINI SWEEPER (A60432)
UNUSED FUTURE QSJ...
FORD 3000 TRACTOR (A60430)
FORD 3000 TRACTOR...
Toyota 7FGCU25 5,000 LB Cushion Tire Forklift (A59228)
Toyota 7FGCU25...
