John Deere 4410 Belly Deck drive box leak
   / John Deere 4410 Belly Deck drive box leak #1
atomic41
Troutville, VA
John Deere 4410
Just changed the oil in the drive box at 500 hours. Filled to top of drain plug hole as recommended by manufacturer. Now it's leaking out of the bottom. :thumbdown: Would it be worth the effort to put some some stop leak in and if so, what kind and how much?
   / John Deere 4410 Belly Deck drive box leak #2
Your gear box bearings will tell you to replace the seal and not to use any magical fix-a-leak. I can't imagine a seal would cost much more than a few dollars.
   / John Deere 4410 Belly Deck drive box leak #3
I find it strange it would begin leaking just after you changed the oil. Are you sure you didn't overfill it and heat expansion pressurized it and forced it to leak? Just wondering.
Yea. I'm not a fan of the stop leak either. It boggles my mind why it started leaking too. I filled it right to the bottom of the drain plug as suggested.
   / John Deere 4410 Belly Deck drive box leak #5
Did you use 80-90w gear lube? Synthetic? I changed mine at 500hours, no leaks. I had to drill the fill/drain plug to get it out, the "Allen" hex rounded.
Yes. Used the correct weight. I'm now suspect the belt was too tight.
2011 Ford F-350 Knapheide Stakebed Truck (A52377)
2011 Ford F-350...
2017 KENWORTH T680 TANDEM AXLE SLEEPER (A53426)
2017 KENWORTH T680...
2015 Linde H35D 4,350lbs. Diesel Forklift (A51691)
2015 Linde H35D...
AMADAS SPC-6 LOT NUMBER 257 (A53084)
AMADAS SPC-6 LOT...
