John Deere 4410 Belly Deck drive box leak
   / John Deere 4410 Belly Deck drive box leak #1
atomic41
Troutville, VA
John Deere 4410
Just changed the oil in the drive box at 500 hours. Filled to top of drain plug hole as recommended by manufacturer. Now it's leaking out of the bottom. :thumbdown: Would it be worth the effort to put some some stop leak in and if so, what kind and how much?
   / John Deere 4410 Belly Deck drive box leak #2
Your gear box bearings will tell you to replace the seal and not to use any magical fix-a-leak. I can't imagine a seal would cost much more than a few dollars.
   / John Deere 4410 Belly Deck drive box leak #3
I find it strange it would begin leaking just after you changed the oil. Are you sure you didn't overfill it and heat expansion pressurized it and forced it to leak? Just wondering.
Yea. I'm not a fan of the stop leak either. It boggles my mind why it started leaking too. I filled it right to the bottom of the drain plug as suggested.
   / John Deere 4410 Belly Deck drive box leak #5
Did you use 80-90w gear lube? Synthetic? I changed mine at 500hours, no leaks. I had to drill the fill/drain plug to get it out, the "Allen" hex rounded.
Yes. Used the correct weight. I'm now suspect the belt was too tight.
2025 New/Unused Wolverine 72in Skid Steer Hydraulic Rotary Tiller (A51573)
2025 New/Unused...
2016 Dodge Charger Sedan (A51694)
2016 Dodge Charger...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
Ford Super Duty FX4 Pickup Truck Bed (A51691)
Ford Super Duty...
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
