John Deere 4400 driveshaft seal leaking. need advice
   / John Deere 4400 driveshaft seal leaking. need advice #11
Ok bud I’ll get some info sent your way Monday!!
any other info? its leaking pretty bad, but I found if I keep it in 2wd it leaks less.
   / John Deere 4400 driveshaft seal leaking. need advice #13
Good luck with your repair.
   / John Deere 4400 driveshaft seal leaking. need advice #14
What else do you need? I bought the service manual for my 4400. Is there any play in the shaft? Might want to replace the bearing while you're in there.
I don't feel any play in the shaft(side to side) it just goes in and out during engagement and disengagement of the MFWD. I haven't gotten the manual yet but I should. you make a good point I was actually was just thinking about that. sisu was gonna run me through how to disassembly, cause it looks like a pretty big deal to get in there. it sure is leaking and the work goes on so I'm just topping it off as I go...... how good is the manual? does it walk you through procedures like this one?
I also got the manual, and it looks like I will need to split tractor(front) and remove hydro-static transmission to get to seal. It doesn't look to hard but I wonder about splitting, do I need the JD wheel stands or could I use my jack stands and hydraulic jack? I also have mini excavator that could help to support one halve if needed.
   / John Deere 4400 driveshaft seal leaking. need advice #17
I've split several tractors between 15-50 hp, with a combination of blocks of wood, jack stands, floor jack, bottle jack, and/or engine hoist you can always find a way.
Ok so I got the manual, but to be honest kinda not been motivated to get into this tractor split just yet. anyone have pictures or videos of splitting one just to get me over the scaredy cat hump.
   / John Deere 4400 driveshaft seal leaking. need advice #19
Ewasson
Can't blame you for being a bit apprehensive about the task.
Can you describe or post pics of where you will be working on the 4400? May help to give suggestions on how to proceed.
Doing some rigging with stands that can roll and at the same time maintain balance and control of the front and rear parts is basic to the splitting. The front part will tilt about the front axle so control of that tilt is important. Some may be done with simple wedges on both sides of the axle housing and some times the stand can have built-in support to prevent tilting.
But pics as you go will bring good advice from TBN members, on both how to proceed as well as warnings of any potential problems.
Will look for some videos.
How To Split A John Deere Tractor (443 Part 1) - YouTube
http://www.tractorbynet.com/forums/john-deere-ag-tractors/201150-splitting-2355-a.html
And my tech manual has sections on splitting the 4400 front and the rear... hopefully yours has that as well.
   / John Deere 4400 driveshaft seal leaking. need advice #20
It is great that you have the mini-X. I always use a working tractor to help me split one, then an overhead
hoist to help me put them back together. If it is still running, take the FEL off under power, or it is a PITA
otherwise.
Note that support for the split halves do not have to be very stout, but having wheels on the stands
are important. Just a furniture dolly and a jackstand is enough. Hydraulic jacks leak down, so beware
of that.
My 4300 project, more than 8y ago:
http://www.tractorbynet.com/forums/...re-4300-complete-rebuild.html?highlight=deere
2009 CHEVROLET SILVERADO 2500HD (A48992)
2009 CHEVROLET...
2019 KENWORTH W900 SLEEPER TRUCK (A45679)
2019 KENWORTH W900...
2022 Polaris Ranger XP Northstar (A47371)
2022 Polaris...
1985 SHOPBUILT UTILITY TRAILER (A48992)
1985 SHOPBUILT...
TOFT 08ER Excavator Ripper (A49251)
TOFT 08ER...
Brush Hog Mower (A49251)
Brush Hog Mower...
