John Deere 4400 cranking problems
/ John Deere 4400 cranking problems #1
spearsl
Hickory, NC
1998 John Deere 4400
I have a John Deere 4400 which has always cranked at the touch of the key. However for the past month or so it will crank one day and not the next. When it does crank it will not recrank if you turn it off. It is usually 2 days before it will crank again. It will turn over but not fire even if you just turned it off. I have checked all I know so any help will be appreciated.
/ John Deere 4400 cranking problems #2
When you turn the key on do you hear the fuel cutoff solenoid activate? You should hear a click from the motor just to turn the key on and not actuate starter.
/ John Deere 4400 cranking problems #3
Cranking over but no start .....
......No cranking
Two TOTALLY different things. Your post says it wont crank.....then later you say it will crank but not fire. So which is it?
Might also help to mention what you have already checked in a little more detail than "all I know".
/ John Deere 4400 cranking problems #5
Seems there is another thread going at this time on an intermittent starting JD4400.
Check it as the replies will also apply to your situation.
[video]http://www.tractorbynet.com/forums/parts-repairs/346593-jd-4400-hst-wont-start.html[/video]
Yes i hear the click.
The tractor will always turn over but does not always cranks. Hooe that helps you.
/ John Deere 4400 cranking problems #8
Does the starter turn over and try to crank?
/ John Deere 4400 cranking problems #10
I give up
/ John Deere 4400 cranking problems #11
You are positive that you hear the fuel solenoid clicking when you turn the key on and off during the time it will not fire during turning over? During the next no start turn off and on the key several times to listen for the click.
2013 ISUZU NRR 4X2 S/A SERVICE TRUCK (A66091)
2013 ISUZU NRR 4X2...
2025 Sickle Bar Mower Mini Excavator Attachment (A66734)
2025 Sickle Bar...
2005 MACK CV713 MIXER TRUCK (A67714)
2005 MACK CV713...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
2018 GENERAC...
2006 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A67714)
2006 TROXELL 150...
2002 12ft Haulmark KD7X16WT2 Cargo T/A Enclosed Air Cascade Trailer (A66738)
2002 12ft Haulmark...
