john deere 4320 compact tractor
/ john deere 4320 compact tractor #1
Hoef
burleson texas
4320 compact
Was mowing yesterday and started loosing fluid, that appears to be coming from under the instrument panel may be related to power steering. How do I get a closer look at it and what might it be. I know its hydraulic fluid lost steering and would barely move forward, stick was way low
/ john deere 4320 compact tractor #2
You''ll really want the service manual to start disassembling...however, assuming it's not a cabbed 4320, it should go something like this:
a) Remove fuse panel door
b) Remove key panel (just above the fuse panel)
c) Remove the cowl panels.
That should give you access to anything below the instrument cluster to start your trouble-shooting.
As a couple reminders, the Deere hydraulic systems operate at >2000 psi. Use extreme caution when working around hydraulics. Should you get hydraulic fluid injected in to your skin, go to the hospital immediately.
Also, goggles are a must.
Thanks will give it a try tomorrow its 108 heat index today and I am stuck in the field
/ john deere 4320 compact tractor #4
Hope it's something like a loose fitting.
I hope it's simple also I just put in a water pump last week and the pump cost me $235 that was just for the part I did the work myself
SOUTHERN FRAC MANIFOLD (A68842)
SOUTHERN FRAC...
Yamaha 150 V6 150 2-Stroke (A66738)
Yamaha 150 V6 150...
2018 CATERPILLAR 950M WHEEL LOADER (A65056)
2018 CATERPILLAR...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
2011 PREMIER PUMP AND POWER 3IN 3HC-DM16 TOWABLE PUMP (A67714)
2011 PREMIER PUMP...
Doesnt start. No compression. (A64553)
Doesnt start. No...
