John Deere 4310 F5 fuse and PTO connection
   / John Deere 4310 F5 fuse and PTO connection #1
Spectre
Fort Walton Beach
John Deere 4310
My 4310 has had an issue for a while now, but it appears to have gotten worse.
I have a John Deere 4310, E-Power reverser with mid mount mower deck powered by the mid mount PTO.
1. When I engage the Mid Mount PTO, the F-5 fuse blows
2. The rear PTO worked fine, so I just stopped using the mid mount deck and just used a bush hog.
3. Now, nothing works and the F5 fuse blows as soon as the ignition is switched on
4. Sometimes it will start for a few minutes, then the F-5 fuse will blow
5. I traced the wires looking for breaks and shorts...but did not find anything.
6. I isolated the relays one-by-one but the fuse still blows
7. I disconnected the plug leading to the MFWD and rear PTO and the fuse does not blow...and tractor starts normally
8. I repeated this several times with the same results...and have went through a whole lot of fuses
Can anyone offer guidance?
Bill
   / John Deere 4310 F5 fuse and PTO connection #2
You are on the right track. Fuse F5 is switched circuits. All the lights are on different fuses so they can be ruled out. So is the computer. This leaves the PTOs and MFWD and possibly some transmission switches (I do not have an electrical diagram). Where did you do #7 above? At the switches? before the switches? At the solenoids?
Instead of going thru multiple fuses, rig a test light across the fuse terminals (F5). This puts the light in series with the circuit. A short that would blow a fuse will just light the test light.
Reconnect everything. Switch the key ON. If the light comes ON, something is shorted to ground. Disconnect one item at a time (I would start with the switches; MFWD, mid PTO, rear PTO, any transmission switches) and reconnect until the light goes out. Next you need to determine if it is the switch or what the switch controls, do this by disconnecting what it controls (I am guessing a solenoid) one at a time and reconnecting if not the problem.
You may have to operate the switches to find the problem.
My guess is the MFWD solenoid. Some tractors energize the solenoid when in two wheel drive and if it fails default to mfwd. So if you switch mfwd ON it may no longer blow fuses if that solenoid is shorted.
It also sounds like the mid PTO solenoid is shorted.
If the light stays on with the solenoids disconnected, there is a short in the wiring to them, or possibly a bad switch.
GOOD LUCK
Thanks Zebrafive, I will pursue those leads. As for #7, I disconnected the plug leading to the solenoids...right next to the solenoids, so there was only a pigtail coming from each solenoid.
Best wishes,
Bill
   / John Deere 4310 F5 fuse and PTO connection #4
Best wishes,
Bill
Really sounds like bad/shorted solenoids now. I am guessing, Mid PTO and MFWD, maybe rear PTO
A few minutes ago when I returned from work, I connected the solenoid lead and placed the MFWD switch into the engaged position. When I switched the ignition on, F5 did not blow. When I turned off MFWD, F5 blew right away. I am still trouble shooting, but looks like we are narrowing it down Zebrafive!
More info: I repeated the above steps and turned the key on with the MFWD and Rear PTO solenoid disconnected and the Mid PTO solenoid connected. When I cycled the mid PTO switch, I could hear the solenoid actuating...and F5 did not blow. So far, it appears I have a bad MFWD solenoid...and maybe the rear PTO solenoid as well.
All, thanks very much for the advice. I purchased a new solenoid for the MFWD and replaced it. Quite a messy task I will say. The tractor now starts without blowing F5, the rear PTO engages fine also. I think I still may have a problem with the mid pto though. When I engage it according to the operators manual, I can hear it engage and begin to turn as soon as I pull up on the mid pto switch...before I engage the rear pto. I also found it would also blow F5 when cycling the switch. After I disconnected the plug on it near the solenoid, F5 no longer blew when I cycled the switch. Opinions?
   / John Deere 4310 F5 fuse and PTO connection #9
Spectre, I have a PDF of the Deere Tech manual you're welcome to, if wanted, shoot me your email
Joe
Thanks Joe, but I already have a copy.
I think I just stepped into Bizarro-Land today. After checking out the PTO as described in an earlier post, I loaded the tractor on my trailer and took it to the work site. When I started it, all seemed normal, but after unloading from the trailer, I engaged the MFWD and the rear PTO engaged (bush hog was attached). When I turned off MFWD, the rear PTO disengaged. I tried to engage the rear PTO with the rear PTO button and it would not engage. Even though the rear PTO engaged and MFWD engaged and disengaged with the proper switch yesterday (about 10 times) when I engaged them today, all was different. After the engine ran for about 15 minutes, it suddenly stopped and all dash lights went out...dead, dead, dead. I checked all the fuses and none appear to be blown. Might be time to drag it onto the trailer and take it to a dealer for some serious circuit analysis.
Could this be a problem with the computer?
   / John Deere 4310 F5 fuse and PTO connection #13
Sounds like some wires may be melted together. Just for fun, check your grounds. Battery to chassis and chassis to engine. Take them apart, not just look at them. Just a thought.
The problem has been located and repaired. There were actually two problems. The first was a shorted Mid-PTO solenoid (causing the F5 fuse to blow). The other was a broken wire in the seat switch. It was hard to see and the only way it was found was pin checking voltages. Thanks for the help all.
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
ExMark Vantage 48in Stand-On Commercial Mower (A59228)
ExMark Vantage...
Crown RM6025-45 4,500 LB Stand-On Electric Forklift (A59228)
Crown RM6025-45...
2017 Ford Transit 250 Cargo Van (A59230)
2017 Ford Transit...
159119 (A60430)
159119 (A60430)
John Deere 5055E (A53317)
John Deere 5055E...
