John Deere 4310 codes
/ John Deere 4310 codes #1
tomdelong
Am getting a long followed by 3 shorts code > What does this mean? Tractor won't move forward or back. Lifts front and back work.
/ John Deere 4310 codes #2
The codes that show with the long (2 seconds) followed by three shorts (and then either followed by another single short or two shorts) but you don't mention what follows after the 3 shorts. Can you reply with that answer and what is your 4310... forward/reverser or other?
From the tech manual that covers the 4310, the following from the code chart. tried to type it out, but lose the symbology. Code 31 is a 2 sec. long, followed by 3 shorts, followed by on short. Code 32 ends with two shorts.
31 -/---/- //Machine does not drive // Inch pedal potentiometer is out of range on the low end. Clutch Position Potentiometer Adjust clutch position potentiometer to within specification.
See ePowrReverser Potentiometer Calibration.
32 -/---/-- //Machine does not drive // Inch pedal potentiometer is out of range on the high end. Clutch Position Potentiometer Adjust clutch position potentiometer to within specification.
Didn't notice anything after the 3 shorts. My 4310 is the E-hydro Is the calibration routine fairly complicated? Did notice the tractor continued to roll forward or back after I let off the pedals ? Thanks Tom
/ John Deere 4310 codes #4
I'll look again to see if the e-hydro has codes.
Ok, found it under e-hydro.
The long, three shorts has to do with forward reverse pedals.
Controller receives a command from both pedals at the same time.
Goes on to say.
Error status will reset when both pedal commands return to zero.
So look at a reason one or the other pedal is not returning to neutral position. Snow? debris?
Says there is no adjustment.. just that they need to return to home.
Thanks much. I'll check it out after our big snow. Thanks again!
1997 Chevrolet Kodiak C6500 Aerial Crane (A62613)
1997 Chevrolet...
2016 Ford Transit 350 Cargo Van (A61573)
2016 Ford Transit...
FRESHLY REFURBISHED! 2016 KBH Fertilizer Tender Trailer - Isuzu Diesel (A63688)
FRESHLY...
PRENTICE 2384C LOG LOADER (A64276)
PRENTICE 2384C LOG...
2013 Chevrolet Traverse SUV (A61574)
2013 Chevrolet...
HLA Attachments Loader Forks (A64119)
HLA Attachments...
