John Deere 4300 won't crank
   / John Deere 4300 won't crank #1
reelk
John Deere 4300
I have a 1999 John Deere 4300 that won't crank. I bought it new and it has served me well. It currently has 1300 hours. Prior to now, I might have had to jiggle the power reverser lever whilst turning the key to get it to turn over. Now that trick no longer works. It's as if it is in gear. I put it in neutral with the range selector, no start. I'm convinced the power reverser is not moving it to neutral. Any ideas?
   / John Deere 4300 won't crank #2
A simple test light will help you diagnose your problems. More than likely a safety switch for the reverser, or another causing the problem. With it in neutral, and key on, you can check for power in/power out when the switch is activated. Once you find it, you can run a jumper wire temporarily to confirm, then replace the switch.
I'd have to guess that, or a bad ground on the battery cable.
   / John Deere 4300 won't crank #3
   / John Deere 4300 won't crank #4
There are a couple of relays that have to engage to crank , the K4 relay is the engine run relay and is probably the 'click' you hear when you turn the key but when you turn the key to start it must engage the K2 start relay which sends power to the starter solenoid. If it don't crank it may be the relay, you can get them online, or at JD or possibly at Auto Parts store, had the same problem replaced the relays and the diode block and problem solved, online bought a box of ten for $20 plus shipping.
2018 KOMATSU D51PX-24 CRAWLER DOZER (A51246)
2018 KOMATSU...
Simpson 3100 PSI Gas Pressure Washer (A51573)
Simpson 3100 PSI...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
2016 JOHN DEERE R4038 LOT NUMBER 195 (A53084)
2016 JOHN DEERE...
2016 R&R Products 331 LP Reel Mower (A51694)
2016 R&R Products...
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
