John Deere 4300 sync reverser question
/ John Deere 4300 sync reverser question #1
swarley814
Ford 1720
Couple questions about the sync reverser issues I’m having. When doing loader work I am occasionally having the forward/reverse lever pop out of forward and into neutral. It doesn’t do it if I’m already moving forward, it’s usually if I’m backing up then put it into forward and let out the clutch it sometimes pops back to neutral. It feels like whatever holds the lever in position is worn out maybe. Sometimes when switching into reverse it whines a bit like it’s halfway in gear, if I hold back on the lever it goes away. Occasionally when putting it in forward and letting out the clutch it doesn’t move, if I tap the clutch again it will lurch into gear. Sometimes I have to put it back to neutral then back forward and it works like normal. Am I looking at something with the sync reverser lever that needs replaced or more deep issues into the clutch/transmission?
/ John Deere 4300 sync reverser question #2
After a quick look at the parts catalog, looks like JD has a fair complex linkage for the forward/reverse lever with loads of points where it can get play and lose range of motion.
I suspect it's not moving the shift forks far enough inside the transmission and you may have to adjust the linkage to achieve that or just check for any wore out parts, balls joints, etc.
/ John Deere 4300 sync reverser question #3
UNUSED INDUSTRIAS AMERICA C10 10' FEEDER TROUGH (A60430)
UNUSED INDUSTRIAS...
2016 TAKEUCHI TB216 EXCAVATOR (A62129)
2016 TAKEUCHI...
2012 MACK GRANITE-GU713 (INOPERABLE) (A60736)
2012 MACK...
2010 Toyota Rav4 SUV (A61569)
2010 Toyota Rav4...
2025 Pabreak Hydraulic Brush Cutter Skid Steer Attachment (A61567)
2025 Pabreak...
Welcome to the Farm Metal Decorative Sign (A61569)
Welcome to the...
