Elembytes
Hello: I have 1 1999 John Deere 4300 and I currently am having issues with my temp gauge on the console dash. Sometimes it will work just fine but lately it has slowly moved over to the pin on the right side of the gauge past hot. Sometimes the needle gets stuck there and I tap it and it comes down AFTER I shut it off. BUT, mainly once the tractor is started before the thermostat opens the needle on the gauge slowly climbs and goes way over to the right. Once in a blue moon it will spike over there and you can tell it's a short, or electrical in nature. Even my tachometer will at times pulse. I had a mechanic test the sending unit and said ti appeared to him that it was shorting out inside the sending unit. So I spent $73 on a new sending unit. It solved the issue for a day and then I am right back where I am now. The mechanic said it could be the gauge itself and of course if it is I have to replace the entire console $573.00.
Now this is what's odd, my fuel gauge used to do this behavior and has stopped and now it's the temperature gauge. I tired to have John Deere service shop look at that issue last fall. It's not doing it anymore. I am very frustrated by all this.
I suppose I could put another temperature gauge on the tractor somewhere but what kind and where is the bet place to mount one?
IF I chose to invest in a replacement console cluster, do I start my engine hours back at zero? OR does that transfer to a new console? Since these are not cars who do people notify someone else that the gauge cluster was replace?
Anyone with basic layman terms with knowledge on this please let me know. I think a water temp gauge is important to know the health of your machine while using it. Thank you in advance!
