John Deere 425
   / John Deere 425 #1
langill2
425 garden tractor
With rotiller on; & ingaged the blades stop turning as soon as they are lowered in to earth.Hydraulics are all working. Any help appreciated. Lorne
   / John Deere 425 #2
Lorne,
Is this the hydraulic driven roto-tiller? If yes have you tried running the tiller in both directions? Reason for asking is that there could be a run down option or anti reverse option on those tillers preventing operation in one direction.
If PTO belt drive then I would start looking for loose belt, slipping clutch etc.
   / John Deere 425
Thank you for the reply.The roto-tiller is hydraulic driven. I will have to find out about the condition's you mentioned. As the unit was used mainly with the roto-tiller; I was thinking clutch slipage ; want to check options before getting to deep.
   / John Deere 425 #4
I doubt there is a slip clutch on the tiller since it is hydraulic drive.
I presume this has the pump driven by the electric PTO clutch. First thing I would check is the belt driving the pump to make sure it is not slipping
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
(2) Anchor Hedge Posts (A50515)
(2) Anchor Hedge...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
Livestock Stall Fan Cage (A50515)
Livestock Stall...
2015 Z Master Professional 5000 Series 60in Zero Turn Commercial Mower (A50322)
2015 Z Master...
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
