John Deere 425 power steering hose replacement help
   / John Deere 425 power steering hose replacement help #1
Jeff4008
racine wisconsin
425 JD
Hello I need to replace the hoses on the power steering pump
Do I just remove and replace or is there something
I need to bleed after replacement.
The hoses have a hole in them from rubbing together over the years .
There is also a allen bolt in the center of the mount flange that holds
hoses to pump with two bolts on the outside edges
I haven't remove it yet looking for help with this repair so I don't muck it up thanks for your help
   / John Deere 425 power steering hose replacement help #2
The easiest and best way is to get the replacement hoses from Deere. You WILL pay a premium, but the hoses will fit without a fight. Ask if there are any gaskets or o-rings to be replaced.
I get to call the Deere dealer Monday morning for parts too.
   / John Deere 425 power steering hose replacement help #3
the system will self bleed , just replace the hoses, fire it up and turn the wheel lock to lock a few times then top off your hydro oil level.
   / John Deere 425 power steering hose replacement help #4
Need to replace power steering hose on jd 425, looking for any input. its left side hose that comes out of pump
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2015 FREIGHTLINER CASCADIA DAYCAB (A52472)
2015 FREIGHTLINER...
NO TITLE - Utility Trailer (A50514)
NO TITLE - Utility...
43013 (A51691)
43013 (A51691)
2015 Chevrolet Silverado 1500 Pickup Truck (A50323)
2015 Chevrolet...
2016 FORD F550 CREW CAB SERVICE TRUCK (A52141)
2016 FORD F550...
